01-28-2018, 11:41 PM | #1 |
Help!! Heavy duty tire / inter tube for hawk 250 dual sport
Hey, I’m a big guy whos 6’4 weight 340 pounds. I was wondering if anyone could recommend any tires and heavy duty tubes for a person my size. In the last 3 months I have replaced my rear inter tube twice I’m thinking because Of my size. Does anyone have any recommendations on upgrade tires and inter tubes for a big guy? Also are there any tubeless tires that may work? Any help would be appreciated. P.S this is for off roading only
Thanks |
01-28-2018, 11:58 PM | #2 |
Tires & Tubes
I’m running IRC Heavy duty tubes and rim strips and Shinko 244 tires. I’m 6 ft and weighing in at around 220-230 with gear. I have had no problems with this setup.
Let us know what you decide to go with. Ride safe!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
01-29-2018, 02:03 AM | #3 |
As my name implies, I am a fellow Sasquatch. Same height and a bit lighter (260-280 depending on my diet at the time lol).
Tire wise, most off-road tube style tires should be more than up to the task as long as they are at least a 4 ply. In the realm of Tubes, I have found nothing more durable than Michelin's Ultra Heavy Duty tubes. Better seam design and placement and really thick. They will add quite a bit of weight to the tires, so be prepared for that. As with any tube though, generous amounts of baby powder inside the tire between it and the tube is important. I would suggest looking over your rear wheel very carefully when you remove the old tube and tire. Check for anything sharp on the inner rim surface that could rub through the tube. Myself and a couple others had this issue. Also check that the spokes are not poking through the rim strip, and/or the rim strip is in good shape and not shifted, others have run into this problem. My last suggestion, and a way to bypass the whole tube issue all together, would be to drop the coin on a Tubliss setup. You can get the front and rear together in a package for a bit of a savings. https://www.amazon.com/gp/product/B0...A3TN6L67UOBHZZ It's pricey for sure, but it's been tested and run with 0psi tire pressure over several miles with no tire or rim damage.
01-29-2018, 08:36 AM | #4 |
i am similar in stature, and found good luck with michelin tubes as well... for added security, i would recommend a rear rim lock for the tire as well, as all the flats i had (before switching to cast aluminium one piece supermoto rims and tubeless tires) were the stem pulling out of the tube, due to wheelies (trying to get over obstacles on the trail) and not from punctures...
01-29-2018, 09:58 AM | #5 | |
01-29-2018, 12:22 PM | #6 |
X3 on Michelin Ultra Heavy Duty tubes. I use a six foot length of Gorilla tape (torn in half lengthwise) as a rim strip. Much better than a rubber rim strip.
01-31-2018, 12:06 AM | #7 |
the hawk tires are pretty heavy duty. probably what your getting like the others have said is punctures from the spokes or the tire spinning on the rim.
02-02-2018, 10:21 AM | #9 |
If the spokes are sticking through the nipples (which is rare), a little Dremel work will fix it.
02-03-2018, 07:10 PM | #10 |
plus some duct tape over the whole rim along the nipples on the inside of the rim.
02-04-2018, 06:29 PM | #11 | |
