Old 12-23-2017, 08:35 AM   #1
scatgo   scatgo is offline
Charging System
Can some one help me figure out how to test my stator? Right now it looks like my battery is not charging an I dont know what wires from the stator are suposed to feed the voltage regulator. So far these are the tests i did. Tested battery volts with the engine running and not running. Voltage is the same 12.5. Removed battery cables with engine running and it stays running. Tested battery cables after removing from battery with enging running and I get 0 volts. The ATV is a 2005. Might be a Ching 200 or Peace 200.
Old 12-23-2017, 11:59 AM   #2
ben2go   ben2go is offline
It sounds like your regulator rectifier pooped out. I'm not sure what style stator that engine has so I can't advise on proper testing methods.
Old 12-23-2017, 05:47 PM   #3
Originally Posted by ChondaChondaChonda View Post
This might help:
That's for s three phase AC stator. I'm pretty sure his ATV is a single phase AC. Without seeing it, I can't tell.
Old 12-23-2017, 11:50 PM   #4
humanbeing's Avatar
Ohm readings of typical chinese reg/rec: http://www.microsofttranslator.com/b...fo1%2Fcpdt.asp
Anyway the troubleshooting guide in Chapter 15 is worth to read
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
