09-27-2017, 05:48 PM | #1 |
Engine guard.
Hi friends,
I managed to find some bits for my ZS200 CG clone. Finally, I managed to find an engine bottom protector. Not that I really need it, but it looks nicer with it. So, I got the guard but without any bolts, spacers, rubber washers.... So, I found a parts catalogue for my bike and here is the pic of it (at the bottom). What i need is some photos of the missing parts which are used for mounting the guard. Those are: no. 14, 15, 16, 17, 19, 20. no. 14 and 15 are M8 bolts, which I can search and find appropriate - not a problem 16 and 17 are some kind of rubber washers. I would need a photo of original part? 19 and 20 are something like metal spacers. I would also need a photo if possible or dimensions. Or both With photos I need I think to make something that looks very original to the factory used parts. Any help? |
09-27-2017, 06:36 PM | #2 | |
09-27-2017, 07:31 PM | #3 |
Thanks.
I do not need metal spacers??? I would put them. I wonder what is their diameter and lenght? As I understand, metal spacers are to make exact space between engine and guard also making tight fit guard-spacer-engine. But I could be very wrong. Other option I can think of is, if the O.D. of the spacer is 15mm or less, it can serve as the guide for the guard movement, while the rubber hose is providing damping (if it is supposed to have this movement). I'm talking about the rear 2 mounts. 3/8 inch hose, that is 9.5mm I.D.? Last edited by Kivi; 09-27-2017 at 09:39 PM. |
09-28-2017, 05:57 PM | #4 | |
