07-18-2017, 07:47 PM | #1 |
Basic tools for owner of a Chinese motorcycle
I thought I should start getting a list together of the tools and other items I will need to be a prepared owner of a Chinese motorcycle.
Some things I know and have, like a metric socket set and open end wrenches. Some I know but don't have, like a torque wrench and feeler gauges and spoke wrenches and Locktite. What else does the prepared owner need? Care to contribute to the list? |
07-18-2017, 08:58 PM | #2 |
Compression gauge
Metric allen wrenches BFH and LFH Rubber mallet Flat and phillips screwdrivers Beer and a fridge to keep the beer in Log book Drain pan funnel rags, lots And if the bike has any torx head screws, get some torx bits.
07-18-2017, 11:54 PM | #4 |
Tire Stuff
I picked up some tire spoons, a tube patch kit, air pressure gauge and a valve core remover. Some people are ok with 2 spoons, I like 3. I use rim protectors, but some people don't. Some people use baby powder in the tires to keep the tube from chafing. A bottle of windex helps tires slip on the rim.
There are plenty of YouTube videos to watch on tire changing. Be safe out there!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
07-19-2017, 02:26 AM | #5 |
JIS Philips head screwdrivers and/or bits.
07-19-2017, 06:19 AM | #6 |
There's proper stuff from autoparts store... windex Do a pH paper test will taught u something... Use soapy stuff that are mild to human body (dish soap+ water) if don't had those fancy (proper) stuff...
07-19-2017, 06:31 AM | #7 |
multimeter
07-19-2017, 08:06 AM | #8 |
Sometimes old sckool tech (ie. There's light) is more useful... Bi-color LED circuit tester presented in ANY vehicle's toolkit i owns . Multimeter uses battery & had chips, u NEVER know when will it fail.
07-19-2017, 08:27 AM | #9 |
Good thoughts everyone, keep 'em coming! How about wheel lifts and center stands and jacks? Needed or no? Keep in mind I don't have a helper, so I'm strictly on my own.
07-19-2017, 08:52 AM | #10 |
And what about battery chargers? Any thoughts as to best bang for the buck for motorcycles?
07-19-2017, 09:00 AM | #11 |
I used a floor jack and two ratchet straps to tie off to keep the bike vertical when I jacked it up. If you have a place you can hook a ratchet strap overhead you can use the strap to lift it. I too had no help. I had to unload the crate out the back of my truck using my ATV ramps and pushed it out the back. I also had to assemble by myself. Took me about 4 hours. 1st thing you want to do is fill the battery with acid, that way it has plenty of time to activate the battery properly before putting it on a slow charge.
07-19-2017, 09:09 AM | #12 |
Once finished with the initial battery charge it shouldn't need charging again. It's a good idea to put the brand new battery on a slow overnight charge before putting it into service. I suppose in Michigan you'll need a battery maintainer for winter storage.
I use a couple of automotive jack stands to support the bike in an upright position for changing tires. Never needed to use a jack. |
07-19-2017, 12:27 PM | #13 |
There's this
https://www.harborfreight.com/12-vol...ger-62813.html Or for a few bucks more you can get the battery tender jr brand.
07-19-2017, 01:10 PM | #14 | |
I was looking at this one: http://www.sears.com/diehard-platinu...6&blockType=G6 I am reading the doco and it appears it will do float charging, maintenance charging, desulfation, and even has an app (LOL). The video is a real hoot, reminds me of a viagra commercial, but for a flat battery, not a flat something else. Any thoughts about the one in my link above? Thinking of picking it up tomorrow on the way home from work. |
