Old 04-16-2017, 07:17 AM   #1
rossw   rossw is offline
Gio/Apollo Parts - Oil Drain Plug
When putting my oil drain plug back on my Gio 250 I cracked it :-(
It does not leak, but I don't want to push it and ensure I have a replacement sooner than later.
What do you guys do for parts?
Is it true these bikes at Honda CB clones? Do those parts fit?
I don't really want to pay more for shipping than the part likely costs.
Thanks,
Ross
Old 04-16-2017, 08:31 AM   #2
It helps to know the size and pitch of the bolt. Check out an auto supply store. They have drain plugs for cars that are a match sometimes.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 04-16-2017, 09:06 AM   #3
humanbeing's Avatar
http://bv000245.ferozo.com/despieces...ish%5B1%5D.pdf tells something
36mm (using 24mm wrench) https://item.taobao.com/item.htm?id=525492303489 which same as good old Honda
Typical drain bolt in vertical chonda is 12mm (using 17mm wrench) , there's 14mm variety that common in Suzuki...
Old 04-16-2017, 02:55 PM   #4
Thanks!
