Old 12-03-2016, 02:42 PM   #1
aquaaddict   aquaaddict is offline
Oil level check Help. bashan 250
Just got 1 of my 2 new bashan storm 250. I have changed the oil and filled it back up with rotella 15w-40 so the oil is almost to the top of the oil check window with the bike level. Is this correct? I see the manual says to check the oil level on the dip stick with it leaning onto the kick stand.
Can someone know what way is correct? THANKS FROM A NEW OWNER.
Old 12-03-2016, 02:54 PM   #2
Ariel Red Hunter's Avatar
I think that reading the oil level with the bike on the centerstand at the oil check window, is the way to do this.
Old 12-03-2016, 06:52 PM   #3
Merlin   Merlin is offline
Use the sight glass with the bike level it should be in the middle of the glass. Dont use the dip stick.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 12-03-2016, 10:37 PM   #4
2x
Don't over think it. it would ,however be fine even if I weren't perfect, the thing will run practically dry while climbing telephone poles.
Designed to run practically empty using neglected , thick dusty oil.
oil change ?
