For the first time I took my Blaze onto the main hi way. I opened it up to WOT for a few seconds and I could not get it past 7000 rpm or 55 mph? (gps) At close to 7000 rpm or WOT the engine would start to sputter. If I let off WOT a very small amount it would smooth out. I have 350 miles on the bike. Iam at over 8500 feet and the bike runs fine at all other rpm's. This carb has no air gas mixture screw. Should I adjust the clip on the needle? Iam thinking of getting a new carb with a air gas screw and a new muffler?
For me other then riding the bike this is the fun part. |
If its like the Hawk you will need to change the main jet out to a larger jet. It's running to lean. My hawk was the same way. It had a 98 and I put a 110 jet. Made a huge difference in top end.
I suspect you'll find a pilot mixture screw on the underside of the carb, right where it meets the intake tube. If you feel the bowl, you'll note that there is a relief that accommodates the screw. It is a bear to get at.
That said, it isn't likely to resolve your issue. As Jerry pointed out, you need a bigger main jet. When it comes to swapping jets, I prefer to also swap to a Mikuni, since finding jets is much easier and cheaper. A new Mikuni can be had for less than $40 shipped. To respond to your other question, moving the clip will affect mid-range, not WOT.
The Mikuni jets will fit the stock Hawk carburetor. I got them from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#5 | |
#6 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-04-2016 at 01:38 PM. |
Keihan
#10 | |
#11 | |
I havent fixed them all. Iam running on my old rear steel wheel with the hub fixed with washers. I got a new set of aluminum wheels from Taobao but the rear wheel cant be used as one nipple will not tighten. Iam waiting on new nipples and spokes from china. Other wise Ive fixed nothing. Never got even one part from the dealer I bought the bike from (superiorpowersports.com). The wheels are the only part I could find. I think Ill just have to make due with what Ive got and do my best to make it a good bike. Ill keep looking for the parts but for now its time for a new carb and muffler. I already have a new longer shift lever. |
#12 | |
#13 |
[Main jet]
# system is different http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm Different thread pitch: Keihin .8mm vs Mikuni .75mm NEVER try fit any Keihin jet on Mikuni. The carb will destroyed in no time.
#14 |
Are these 40 dollar Mikuni VM26's Knockoffs from China? Because from my search a genuine Mikuni VM26 is about 90 bucks.
#15 | |
Thank you for asking. |
