05-02-2017, 09:04 AM | #1 |
hawk 250 with vm26 jet size
hey, with a hawk 250 that has an opened up air box and stock exhaust with a mukini vm26 carb what size jets do you use? just so i have somewhere to start. also whats the best carb for this bike? im in upstate ny. heard altitude messes with jetting.
05-02-2017, 12:30 PM | #2 |
I don't have a hawk, but I've messed with several motors just like it. With a 30mm Mikuni, I'd start with a 30 slow jet and a 110-115 main jet (my quad is currently at 110) at sea level. Ride it, do a few plug chops and see what it tells you. As you increase in elevation, lean it out. As it gets colder, fatten it up.
05-02-2017, 12:41 PM | #3 |
the 110 to 115 will be a good place to start, the carb you have is fine, you might want to consider modifying the exhaust also, i cut the cat. converter out and removed the spark screen and drilled additional 1/2" holes in the baffles to allow more flow, i run a 125 main jet with a 25 pilot jet it seems to like it, no issues with it.
i took a ride thru the mountains last week i didnt notice any difference in it. |
05-02-2017, 01:07 PM | #4 |
I was getting ready to order one for my hawk I'm running stock carb now and it isn't reliable:( . I didn't wanna have to change jets I was hoping it would be good to go without messing with it . Having second thoughts now . Maybe cheaper to just change the jets in my stock carb
05-02-2017, 02:53 PM | #5 | |
Welcome to the world of carburetors. Once you have it setup well for where you live, it should do ok most of the time, but a drastic enough change in the climate and it will start to misbehave - I.E. If you set it up on a 90 degree day and a few months later you go to ride on a 40 degree day, it may act a bit lean and vice versa. This is why it's recommended to have an assortment of jets on hand. Once you figure out the right combo, usually you can get by without tinkering too much, but it is just the nature of the beast. Don't let it discourage you too much though. These carbs are easy to access, and even easier to swap jets on |
05-03-2017, 11:58 AM | #6 |
To add to that, the 30mm Mikuni that is so prevalent on eBay is very easy (and cheap) to find jets for. If you really want to get into it, you can drill jets out to just about whatever you wish. I use a numbered drill bit set that goes as small as #60 for the main jet, but the slow jet requires an even smaller set that goes down to #80.
05-04-2017, 03:24 PM | #7 | |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 this is the carb i got, and i cant seem to find slow jets just what are called main jets, idk of their any different other than jet size. the kit i got for the carb come with jets that are too big for using as an idle i think #88 x 1 #90 x 1 #95 x 1 #98 x 1 #100 x 1 #105 x 1 #110 x 1 #115 x 1 #120 x 1 #125 x 1 |
05-04-2017, 03:50 PM | #8 |
2016 Green Bashan Brozz. |
05-04-2017, 04:22 PM | #9 | |
https://www.jetsrus.com/a_jets_by_ca..._selection.htm |
05-04-2017, 04:37 PM | #10 |
The pilot on the Mikuni clones should be the VM28/428, but as da4design suggested, remove yours and check before ordering to make sure.
12-07-2018, 03:49 PM | #11 |
I have the 2019 Tao Motor TBR7 250 which is basically another version ofthe Hawk. Factory carb ran ok, but sputtered pretty hard at 3/4 to Full throttle. Installed Mikuni carb 110 jet, fuel screw out 2 turns from tight, needle jet set one click down from the top (how it was in the box). Air box and exhaust are factory. This eliminated all of the sputter, and gave the bike overall a much zippyier feel to it. Only other adjustment I had to make was the idle screw maybe 1/8" turn if that. I'm at around 900' elevation. Awesome!
hawk 250, mikini, vm26 |
