Old 05-22-2016, 10:34 AM   #1
w0ss   w0ss is offline
instructions for changing front sprocket(hawk 250)
I searched but didn't find anything. Is there instructions or a video? All I see mention of is how easy it is but not how to do it
Old 05-22-2016, 11:02 AM   #2
mq1991   mq1991 is offline
If your just changing your front sprocket, your going to need to:
-Be sure your bike is in neutral! You dont want the transmission taking the force of the wrench tightening and loosening the sprocket. You can put a screwdriver in one of the teeth of the rear sprocket to lock it in place.
-Loosen your rear wheel, and chain adjustments(Still leave them slightly tight until you get the old sprocket loose)
-Remove your shift lever
-Remove the sprocket cover, The bolts top and bottom of the cover where the chain disappears into the engine.
-Leave the chain over the sprocket and around the rear sprocket
-Remove the two bolts holding the old sprocket on, and remove the retaining clip.
-Loosen the rear wheel adjusters enough to remove the old sprocket, and slide the new sprocket with chain over the shaft.
-Get the chain tight enough to not skip on the sprocket
-Put the retaining clip back on, and reinsert the two bolts (With Blue Loctite!) to secure the sprocket in place.
- Many have had trouble getting the gear cover back on after installing the larger sprocket, mine gave me a little trouble, but a little wiggling and persuasion should get it to seat back into place. Make sure you dont pinch any wires coming out of the stator cover. I would use Blue loctite on those bolts as well.
Set your chain tension and tighten everything up! You should be good to go.
Old 05-22-2016, 11:46 AM   #3
I could not get my cover back on with a 17t and the chain on so I had to take the chain off before putting the cover on and feed the chain through after.
Old 05-22-2016, 05:44 PM   #4
Changed the sprocket and the chain. Hardest part was getting the master link on the chain.
I did have to wiggle the sprocket cover to get it past the chain but was really very easy.
Old 05-23-2016, 11:48 PM   #5
paulesmann   paulesmann is offline
paulesmann's Avatar
mq thank you for that valueable info
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 05-27-2016, 08:34 PM   #6
Kdburtch   Kdburtch is offline
I had the same issue with the cover, a light tap of a rubber mallet fixed it in a hurry
