Old 11-15-2019, 05:03 PM   #1
newbie88   newbie88 is offline
Oh No Hawk 250 has difficulty rolling in neutral
So I feel like I might have screwed something up.
Today I was attempting to change out my sprockets, failed and ended up having to put in my original sprockets back in (tipped over my bike in the process and took off the tip of the brake lever )
When I put everything back together, I realized that my bike was really hard to push around in neutral and I would hear a clicking or ticking sound as well.
Did I over tighten my axle nut? Any ideas would be appreciated for this utter newbie.
Old 11-15-2019, 05:10 PM   #2
NzBrakelathes's Avatar
Brake is being held on?? When you broke n bent front brake lever
Old 11-15-2019, 08:55 PM   #3
OneLeggedRider's Avatar
Is your chain too tight?
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 11-16-2019, 04:41 AM   #4
Both good places to start. If it broke the end of the lever off it is possible it belt the lever itself enough that it is applying the brake just a bit and causing drag. Easiest way to see if this is your problem would be to back the lever adjuster off so there is excess free play in the brake lever.
The chain tension and alignment being incorrect will also cause binding which can then cause drag and make the bike hard to move. It may also be the source of the clicking sound you are hearing.
Old 11-16-2019, 02:32 PM   #5
Thank you guys for the suggestions!
I realized my chain was way too tight and that was the cause of the difficulty rolling. Unfortunately I have come across a new problem. The piece of metal connected to the rear brake caliper has cracked due to my use of excessive force in torquing the rear axle nut. The weird thing is that my front brake is also having issues now.
I'm posting some pictures to give you guys an idea of what's going on.
https://imgur.com/a/ZOraNhh
Old 11-16-2019, 06:48 PM   #6
You miss aligned the groove that stops it rotating - you’ll need a new bracket
Old 11-16-2019, 08:20 PM   #7
Gotcha. Where can I buy a new bracket? Is it possible to JB weld it together?
Old 11-16-2019, 09:39 PM   #8
BrianW   BrianW is offline
Location: Wheeling, WV native currently living In Natchitoches, LA
Send a message via AIM to BrianW
I tend to be on the thrifty/cheap side when at all possible but my gut says to replace that bracket. If there’s one place to not cut corners it’s your brakes. No telling when (or how hard) you will need them.
Old 11-16-2019, 09:55 PM   #9
When you mentioned the sound I knew it was the chain being too tight. And Tako is probably right about the bracket not being aligned with the keeper/stop. But dont go crazy with over tightening the rear axle. Invest in a cheap torque wrench until you're ready to spend money on a good one. 30 to 35ft lbs should be more than enough to keep the axle in place. And remember you're squeezing the inner race of some very cheaply made bearings.
Old 11-16-2019, 10:58 PM   #10
NO!!!!!!!
Get a new one from the reseller who sold the bike.
Old 11-17-2019, 08:06 AM   #11
cycleway4   cycleway4 is offline
NO!!!!!!!
Thats a very easy "I second" ...replace it with a new part...no JB Weld there
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 11-17-2019, 10:34 PM   #12
dont think over tightening the axle would do that. probably happened in the spill.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 11-18-2019, 01:37 AM   #13
I agree with that assessment. It is possible that too much compressive force could crack that bit of metal, but it is more likely it cracked due to impact,
Old 11-18-2019, 10:45 AM   #14
I would check with the dealer you bought it from. Also the bracket from the TT250 might be an alternative. https://store.cscmotorcycles.com/TT2...p/zt23-101.htm
2020 Kawasaki Vulcan S
Old 11-18-2019, 01:23 PM   #15
That's unfortunate. I went to the dealer where I bought the bike and they told me they didn't have any of the brackets in stock so it looks like I'll need to buy the TT250 one that you've mentioned JerryHawk. Thanks for the suggestion!
