Old 05-29-2015, 04:56 PM   #1
woodlandsprite   woodlandsprite is offline
woodlandsprite's Avatar
Wrap Around Handguards
Thought we might find a thread for the wrap around handguards useful.
I know several of you have installed handguards. Figured it might be useful to consolidate that info into a thread.
What I've managed to glean so far:
For the most part, guards designed for straight 22mm handlebars should fit - some modifications may be required. ID of the handlebars is approximately 1/2-inch or 12.7mm and may require some reaming with a 1/2-inch bit to make them evenly round.
Spudrider has a set of Tusk Dflex handguards installed:
To complete the install, the master cylinder was swapped and the ends of the levers were trimmed.
I was unable to positively ascertain models from other folks who have shared photos with handguards installed...
Old 05-30-2015, 12:50 AM   #2
Excellent idea. Let's hope other RX3 owners post here after installing hand guards.
Old 05-30-2015, 01:36 AM   #3
Indeed, thanks for starting this useful thread.
The hole in the end of the handlebars has an inside diameter of approximately 12 mm, which is slightly smaller than 1/2-inch. My Tusk D-Flex Handguards are designed for holes at least 5/8-inch in diameter. Therefore, I tapped the 12 mm holes for a 1/2-inch coarse thread, and bolted the handguards to the ends of the handlebars.
Old 05-31-2015, 08:46 PM   #4
bogieboy's Avatar
i have an aftermarket master cyl, but i run Moose racing bark busters on my Roketa/Shineray db07a sumo conversion... drilled out the end of the bars to 5/8", should have tapped for 1/2" like spud...went thru 3 bits drilling...
Old 06-01-2015, 12:54 AM   #5
AZRider   AZRider is offline
Has anybody purchased and installed the hand guards sold by CSC?
George
2016 CanAm Spyder F3-L
Old 06-01-2015, 03:17 AM   #6
Fishman10 installed the Moose handguards sold by CSC, but he bought them elsewhere. You can see the handguards in the following thread.
http://www.chinariders.net/showthread.php?t=14748
Old 06-01-2015, 06:28 PM   #7
For enlarging the handle bar ends, is a HSS 1/2 inch drill bit advised or better to go find myself a 1/2 inch reamer? I'm thinking tapping with a thread is not advised if I intend to use the stock expanders provided with the barkbusters...
Old 06-01-2015, 07:57 PM   #8
fishman10   fishman10 is offline
fishman10's Avatar
handguards
yes i have the exact same ones as sold by csc......but i purchased them from rocky mountain.They are single mount point an not wrap around ,,but they are well made and i dont think they would break in a fall,, Very easy installation,,an offer all the protection i need for sticks an briars.....But spud they are not moose,,,,they are enduro engineering,,,,i looked thru many pages an sites till i found the exact ones csc was selling ,i will get a link up an you compare ,,they are the same.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 06-01-2015, 08:01 PM   #9
fishman10's Avatar
handguards same as csc
https://www.rockymountainatvmc.com/p................i peeled the enduro engineering stickers off mine
Old 06-01-2015, 08:05 PM   #10
Thanks for posting the good information, Fish.
Old 06-01-2015, 08:07 PM   #11
I don't own any reamers. I think you will probably get better use from a 1/2-inch drill bit. The following drill set is on sale at Harbor Freight for $13.99. It has a 1/2-inch drill bit, and it will easily ream out the aluminum.
http://www.harborfreight.com/Titaniu...l_s1011_c2315a
Old 06-01-2015, 08:32 PM   #12
Thanks Spud, I'm going to have to hunt around tho since I don't think it will fit in my drill :P (they aren't stepped down based on the review)
Old 06-01-2015, 11:51 PM   #13
Thanks Fish, much appreciated.
George
Old 06-02-2015, 01:49 AM   #14
You're welcome, and you are correct. I own those particular drill bits, and they are not stepped down.
Old 06-02-2015, 07:15 AM   #15
Huck369   Huck369 is offline
Huck369's Avatar
The installation of the ones I used did not require drilling out the bars, the inserts that came with the kit fit perfect in the RX-3's bars....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
