Old 03-21-2017, 05:13 PM   #1
BigWeld   BigWeld is offline
BigWeld's Avatar
What grease? And, How long is your replacement chain?
Ok, I'm stuck in the frame of mind that once my 18C gets here, I'm taking things apart before it gets the initial assembly. My biggest worry is the bushings, primarily the swing arm and front axle. After reading about owners finding dry swing arm bushings and dusty dry front axles, I just NEED to get in there and see for my own two eyes and repack what I need to before that bike rolls 2 feet.
(This also gives me an excuse to tears down the tail section that comes factory installed and paint it)
What grease do you guys use on YOUR bikes in those applications, and why?
Bonus points for anyone who chimes in with the size/length of chain I'll need to replace the garbage being shipped on my 17T/47T Brozz.
Thanks in advance!
-Eric
Old 03-21-2017, 05:17 PM   #2
Marine grade synthetic grease. Why? because I do go through a lot of water when I go off-road and its waterproof. I actually installed a grease zerk on the swing arm so I can pump it full of grease every once and a while.
2020 Kawasaki Vulcan S
Old 03-21-2017, 06:14 PM   #3
Ski_rush   Ski_rush is offline
Iactually installed a grease zerk on the swing arm so I can pump it full of grease every once and a while.
Does this mean that drilled a hole where the swing arm bolts to the frame?
Old 03-21-2017, 07:03 PM   #4
I drilled and tap the tube the swing arm Bolt passes through.
Old 03-21-2017, 07:08 PM   #5
Do you remember the size of the drill bit and the zerk fitting? And the tap?
I like this idea, and I might as well while I have the tire off.
Old 03-21-2017, 07:15 PM   #6
I used a 1/4 ×20 tap. Don't remember that exact size bit. The bit came with the tap.
Old 03-21-2017, 07:24 PM   #7
Rail32   Rail32 is offline
Rail32's Avatar
#7 or13/64 is close enough .
I also use marine grease and have plans to install zero in mine also real soon
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good
Old 03-21-2017, 07:42 PM   #8
oldscooter   oldscooter is offline
I used Bel Ray marine grease because I had some on hand. Greased front and rear axles, swingarm bolt, front levers pivot pins, and rear brake pedal bolt.
2002 Goldwing
2016 Hawk
Old 03-25-2017, 12:11 PM   #9
BigWeld's Avatar
*bump*. Anybody know what size/length chain is a good replacement for the Bashan Brozz?
Old 03-25-2017, 03:01 PM   #10
Ariel Red Hunter's Avatar
Thanks in advance!
-Eric
I buy my water proof grease at my local Evinrude Outboard shop. I suppose all marine grease is good, but I KNOW that Evinrude and Mercury outboard grease is salt water proof, as well as fresh water proof.
