Old 10-07-2020, 01:44 PM   #1
MIchaelGR   MIchaelGR is offline
Instrument panel and engine start problem
Today i started my rx3 bike.
After some metres driving i realise that the instrument panel back light was "blinking" (on and off fast).
I stopped and switch off the light and then.. my bike switched off!
no panel display at all!
I took off the ignition key, put it back again, switch it on and still nothing on the panel...
I pressed the clutch an the panel indicators appear (while pressing the clutch) , but when i left the clutch nothing again!
Also , only when the clutch remains pressing the rpm clock is working only. That way i managed to start the engine (after several times) but on the panel was only speedo, fuel and the gear number was flashing.
I am really confused on what to do guys..
Is it a battery problem?
Any advice would be appreciated!
(My rx3 is 2015 model with 12000 km
and i am sorry for my bad English!)
Old 10-07-2020, 02:27 PM   #2
franque   franque is offline
Check that all of your grounds (earths) are tight, and make sure the battery terminals aren't loose.
Old 10-07-2020, 03:42 PM   #3
bogieboy's Avatar
second the grounds, the cluster is grounding thru whatever it can find to backfeed to ground.
Old 10-08-2020, 01:59 PM   #4
Thumbs Up problem solved!
@bogieboy
@franque
Problem finally solved today!
Spent 7 hours and the problem was at the key switch ignition lock.
I had to take it off, open it , test it, repair it put it back and..worked like new!
So thank you for your help!
It is really nice knowing that someone will help you somehow!
So, rx3-bikers see you again here!
