Old 03-17-2015, 12:54 PM   #1
DatzMrPig   DatzMrPig is offline
DatzMrPig's Avatar
kill switch??
question does the kill switch ground out the black and white wire to shut off or to run???
Old 03-17-2015, 03:51 PM   #2
To shut off. It's the same system that was used with points ignitions decades ago; ground out the ignition, and the engine dies.
Old 03-17-2015, 03:55 PM   #3
DatzMrPig's Avatar
Ok my idea is that since the igition switch doesn't work and the electric stat doesn't work could i replace the wires in my start button by running the black/white wire and a ground wire and instant kill switch correct???
Old 03-17-2015, 04:00 PM   #4
So I understand, you want to use the start button as the kill switch?
Old 03-17-2015, 04:05 PM   #5
DatzMrPig's Avatar
pretty much i have an isuue in my regular ignition switch I can unplug the black/white wire from the cdi box and it fires right up and runs but can't shut it off so i figured if I run the bl/w wire to the start button and a ground out then its now a kill switch.
Old 03-17-2015, 11:37 PM   #6
Sounds like a good plan, assuming you don't want to fix the electric start.
Old 03-17-2015, 11:38 PM   #7
You could buy a dedicated kill switch for cheap on eBay, like what you'd find on a dirt bike.
Old 03-18-2015, 06:02 PM   #8
DatzMrPig's Avatar
i plan on it just broke at the moment
Old 03-19-2015, 01:07 AM   #9
I've used these kill switches before, and you can pay for them with change from the couch cushions: http://www.ebay.com/itm/Motorcycle-A...50163c&vxp=mtr
Old 03-19-2015, 09:40 AM   #10
DatzMrPig's Avatar
thank you sir those will deffenatly work.
