Go Back   ChinaRiders Forums > General > News, Support, & Feedback
Old 12-31-2010, 01:06 PM   #1
Reveeen   Reveeen is offline
2 cycle area?
I know that 2 cycle stuff is on the "outs", but I *think* a 2 cycle area would be a bonus.
Old 01-31-2011, 06:35 AM   #2
frostbite   frostbite is offline
Sorry I didn't respond sooner.
I'd like to hear opinions, but wouldn't the 2-stroke discussion be covered in the bike specific forums? (e.g. 2-stroke dirt bike, ATV's, etc...).
Frostbite
"The beatings will continue until moral improves"
Old 01-31-2011, 11:01 AM   #3
I can see the benefit of a tech-specific (rather than machine-specific) two stroke area.
Old 02-06-2011, 04:18 PM   #4
BillR   BillR is offline
Can you check the numbers of topics?
Have those related to 2-stroke questions in stated in the subject area..."2-Stroke".
See how much 2-stroke traffic there may be.
I agree with the tech specific instead of just bikes.
It would make it easier to find answers or post information.
Bill R
Old 02-06-2011, 04:36 PM   #5
The search function doesn't always tell the whole story with this forum software.
I agree that a tech-specific two-stroke section would be easier to navigate. That way, when Mr. Reveeen (or whomever) posts an informational topic about reed valves, I can find it.
Old 02-06-2011, 05:34 PM   #6
katoranger's Avatar
Is there much china 2-stroke? The only things I have seen are pocket bikes and a few 50cc scooters.
Old 02-06-2011, 08:20 PM   #7
Does it have to be China-only? Maybe it could be a sub category within Other Stuff.
Old 02-07-2011, 02:46 AM   #8
Jim   Jim is offline
Unfortunately I believe that is not an option with this forum software either.
"Be excellent to each other"
"We are all human. Let's start to prove it!"
Old 02-07-2011, 07:37 AM   #9
katoranger's Avatar
A 2-stroke open to all makes would be fun. I was looking at some detroit diesels to stick into my ranger. :wink:
Old 02-07-2011, 10:07 AM   #10
A Deutz, or a Thermo King (Mercedes) diesel might be a better option (size AND weight). I like the idea of a Thermo King, because they ARE everywhere, and the newer ones are quite light. A Detroit 53 series is really better suited for a 3/4-1 ton.
Old 02-07-2011, 11:10 AM   #11
katoranger's Avatar
That is what I am finding.
Need to research the thermo king options.
Old 02-07-2011, 01:13 PM   #12
The early Thermo King reefers use a 4 cylinder Mercedes Diesel that was found in the 100 series cars from the 60's. It was "tricked out" with a huge oil pan (8 gallons), and 2 huge oil filters, for almost non-stop running between services. In the late 70's the injection pumps were made in Japan under Bosch license, until the middle 80's where the entire units started being made in Japan under license, it was at this time I started noticing aluminum blocks (probably with steel dry liners).
Carrier reefers have always used Kubota (Japan) diesel engines.
The trick is going to be locating a 100 series Mercedes car from the 60's for the transmission (auto, or standard) that, combined with the flywheel, and starter, will give you a package to install.
Horsepower is around 40.
Old 02-07-2011, 01:17 PM   #13
Yeah, I can't imagine trying to use a gas transmission with a diesel. Nor would I want to try and adapt a modern diesel transmission to a Mercedes diesel.
Old 02-07-2011, 01:23 PM   #14
katoranger's Avatar
This is all just a brainstorm. A better suited truck would be easier for the install. Not much room in the ranger.
I don't think the isuzu reefer units will work. Finding a 240d mercedes and just swapping out the whole drivetrain would be a better idea.
Old 02-07-2011, 04:10 PM   #15
240D I *think* would physically be too long (in line 6), they are not as good an engine as the 4 cylinder, though maybe the transmission would fit to the 4?
The concern is not really the transmission, it is the final drive (rear end) ratio. Top gear in most automotive transmissions is 1:1 (unless you are into a 5/6 speed overdrive and big bucks), so you have to pick an engine that works with the rear end ratio you have, or is available. You have to match engine rpm directly to top speed (as the transmission is 1:1) . This is why for a light automotive application you are aiming towards an engine that revs to around 3200-3600. This puts a bit of a damper on engines that will "work".
