Old 12-03-2020, 09:53 AM   #1
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
Gas mileage for people that ride it hard?
I'm getting mid 50s with the stock speedometer (non-corrected speeds), a 130/80/17 rear tire, and a 13T countershaft sprocket. Fresh valve adjustment, plenty of power, running at 8000-9000 rpm on the highway and pretty much accelerating wide open from every stop when riding on backroads. I'm 275 lbs.
Does this sound about right?
Charles.
Old 12-03-2020, 10:43 AM   #2
Pretty normal...given the 13T sprocket and WFO through the gears. The engine can take that treatment, no problem. You are probably giving up 5-6 mpg but that only means you go 20 fewer miles to a fillup. No big deal.
Old 12-04-2020, 09:21 PM   #3
rd1959   rd1959 is offline
I was averaging 56 with the stock gearing, never WTO and all city driving so it sounds about right.
Old 12-06-2020, 05:33 PM   #4
SGCSCRX3   SGCSCRX3 is offline
A 13T sprocket came with my bike when I bought it last month. Not sure I am going to use it yet I'm about 205 lbs. I think I'm going to check valves at 2500. I'm at 1900 now.
Old 12-07-2020, 07:13 AM   #5
Huck369   Huck369 is offline
Huck369's Avatar
I get mid 50's when flogging it, but for my normal commute I usually get 65ish on mine (283 big bore kit) and 14k on it....does a little better with non ethanol gas
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 12-07-2020, 01:36 PM   #6
calvarez   calvarez is offline
I never saw 50 MPG on mine, just under that. I did have a speedo corrector, and without that, the bike thinks you've gone farther than you actually have.
2016 RX3
2002 Honda CBR1100XX
Old 12-07-2020, 09:31 PM   #7
I just installed the speedo corrector yesterday, so I expect my mileage to drop considerably. I finally got the connectors from aliexpress and wired them into the SpeedoDRD, so I could just plug it in and not cut up my wiring harness.
Charles.
Old 06-13-2023, 02:44 AM   #8
HeavenlyMachines   HeavenlyMachines is offline
I measured my fuel consumption in recent trip
Odometer distance: 591km
GPS distance: 560km
Fuel consumption (Pertamax 92 RON): 23.98L
Bike was fully loaded with pillion (88kg + 65kg). Ridden quite hard but with absolute mechanical sympathy.
Calculated fuel economy:
24.6 km/L (odometer)
23.3 km/L (GPS)
Old 06-13-2023, 12:43 PM   #9
bogieboy   bogieboy is online now
bogieboy's Avatar
Right on par with my roketa, mid 50s flogging thru the gears, 60 on the backroads, me weighing 290#, with a 13-38 (520 chain) on a 130/90-16 rear
