Old 02-12-2020, 04:35 PM   #1
toniintc   toniintc is offline
ODB adaptor
Hello,
I have a Helvenco Aero 1000 engine. It's a paramotor engine, for reference here:
https://www.blackhawkstore.com/produ...-package-deal/
The engine is based on the Swissauto 250 with fuel injection added.
I bought a DN-3000 OBD scanner for it as I know it'll work with it, but I need an adaptor to go from this connector:
https://www.amazon.com/clouddrive/sh...TsK6mDSssyjWnH
to this connector:
https://www.amazon.com/clouddrive/sh...B3jIe8jb7H0XMP
Does anyone know of an adaptor like this or at a minimum know where I could buy the oblong end? I've search and searched the internet to no avail.
Thank you,
Toni
Old 02-12-2020, 04:43 PM   #2
bogieboy's Avatar
by the look of the ends, you are looking for a Fiat Lancia to OBD connector... 3 pin with a locator to the obd 16 pin.
https://www.ebay.com/itm/3-Pin-to-16...IAAOxyJ8ZRiNux
Old 02-13-2020, 09:17 AM   #3
Wow, thank you. I borrowed a scanner and adaptor a while back that didn't have the two extra leads. I'm not sure where I'd connect those. Is it possible they are not necessary?
Toni
[QUOTE=bogieboy;328392]by the look of the ends, you are looking for a Fiat Lancia to OBD connector... 3 pin with a locator to the obd 16 pin.
Old 02-13-2020, 09:39 AM   #4
Bruces   Bruces is online now
Just a guess but those other two leads are probably for an outside power supply ,they may not be necessary in your application
Old 02-13-2020, 10:29 AM   #5
bogieboy's Avatar
That would be my guess as well, external power source if the ecu doesnt power the scanner thru the plug.
Old 02-14-2020, 08:24 AM   #6
OK, thank you both, I really appreciate your responses.
Old 02-27-2020, 06:42 PM   #7
I'm back. I received the adaptor today and realized that when bogieboy provided the EBay link above I got so excited that the connector matched that I checked out thinking about the gender. My description was confusing too. One end (the 16 pin end) of the adaptor in bogieboy's product photo is fine, the 3 pin end needs to be female pinned. In other words, now that I have the adaptor above, I just need to find this end:
and I can cut the 3 pin end off that came with the adaptor and put it on.
Doesn't seem like it should be that hard to find, but it's challenging. The 3 pin end has "PA66 B" on it, but PA66 is on a lot of ends so it's not helpful.
Anyone seen a plug like that? Alibaba, Amazon, Ebay, nothing.
Old 06-15-2020, 05:12 PM   #8
rider777   rider777 is offline
Hi @toniintc, did you manage to get the adapter? I'm also interested in testing this.
Are you pretending to try to remap the ECU or only for diagnostic purposes?
