Powersportsmax X-PRO Head
Need to see if this is the head we want
Looks like a CG head to me.
I wonder if it's a higher compression "performance" head or just a stock replacement.
Well it's the same head that JerryHawk250 bought and was discussing with Megadan about on another post but it never specifies if it was the right head it's just a stock replacement other than quench pad is round instead of hahaving squared off part near valves I was reading. But xpro has good reviews.
Also how do you put your signature at the bottom of every post like yours "If I had a doller for every women.......ect ect " do you just copy paste or I'm wondering???
#5 | |
Nobody has used that head afaik. Most either buy a tt250 head, which is a much nicer casting, or use the stock head. The head I used was from ebay and the seller no longer has a listing for them.
Go to User CP in the upper left. You will see it in the menu.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-18-2019 at 05:00 PM. |
OK thanks alot and I'll let you guys know sorry for bugging
