Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Free Classifieds > Complete Machines
Old 07-01-2022, 01:09 PM   #1
TXUTV   TXUTV is offline
2021 TrailMaster TAURUS 200 Golf Cart UTV all-in-one
TrailMaster TAURUS 200 UTV - $6000 OBO
Used one summer season by the Grandparents to get around an RV Park. No sales tax, no dealer prep, no paperwork fees! I just installed a new battery and it's running great. I already have one for myself and don't need another. Only 473 miles on the odometer. Great for general usage around a campground. Where I live (TX Hillcountry), there are just too many hills and not enough torque to haul my big butt up them with speed. Works great in low gear though on the hills even with my weight!
Specifications:
· Engine Type: 4-stroke, single-cylinder, air and oil-cooled
· Displacement: 177.3cc
· Compression Ratio: 8.8:1
· Max HP: 9.5HP
· Bore & Stroke: 62.5X57.8 mm
· Max Torque and Crankshaft Speed: 11.0/4500 N.m/(RPM)
· Nominal Power and Crankshaft Speed: 6.5/6500 kw/(RPM)
· Max Speed: 25mph
· Climbing Ability: 30 degrees
· Ignition: C.D.I
· Starting System: Electric
· Battery: 12V 9Ah
· Carburetor Brand: Deli
· Engine Oil: SAE 15W/40
· Transmission: Auto, L-H-N-R
· Drive Train: Shaft Drive; 2 WD:
· Drive Mode: Rear Shaft Drive, Rear differential
· Suspension, F/R: Front MacPherson, Rear Dual A-ARM
· Brakes, F / R: Both hydraulic brakes, Disc
· Tires, F / R: 24 x 8-12 / 24 x 8-12
· Fuel Tank Capacity: 4.8 gallons
· Wheels: Aluminum
· Weight, G.W. / N.W.: 1136 lbs/ 880 lbs
· Max Load: 800 lbs
· Dump Bed Capacity: 220 lbs
· Towing Capacity: 200 lbs
Dimension Information
· Wheelbase: 63
· OA L x W x H: 108x54x74
· Seat Height: 33
· Min Ground Clearance: 11
· Bump Bed: 26.4X43.4X9.5
