06-05-2020, 09:08 AM | #1 |
TT 250 riders. Are any of you of larger size?
Didn't get much response on my original post so I'll try this. I'm thinking of ordering a TT250. I'm 6'5 275. Am I too big? I want to ride trails and back country roads. I'd like to be able to hit 55mph.
06-05-2020, 09:14 AM | #2 |
The TT250 will fit you perfect. Very similar to Hawk in height and power.
06-05-2020, 11:28 AM | #3 |
Second what JerryHawk250 said , MegaDan "The Worlds Largest Midget" is closeish to your range and he rides a Hawk 250 and is fine ,and the TT250 is basically an upgunned
Hawk .You'll be fine .
06-05-2020, 11:31 AM | #4 |
I'm 6' and currently 240. I fit our TT250 "ok". At your size, I'd be leery. Mrs. 2LZ X husband was 6'6" and 380. There's no way he'd fit.
06-05-2020, 12:22 PM | #5 | |
The only two adjustments that will likely need to be done are adding preload to the suspension tor proper rider sag (they don't come setup for us sasquatches). and likely a set ofadjustable bar risers to bring the bars up a hair and move them forward, but that is personal preference.
06-07-2020, 12:10 AM | #6 |
Thanks Dan.. I keep going back and forth between the TT, Hawk and TBR. I can pre order a hawk fully assembled for $1700ish, the TT is nearly a grand more, and at the end of the day I don't think it's all that different. The hawk seems a tad larger too. So maybe I'm on the hawk train now.
