01-28-2023, 04:31 PM | #1 |
Lycan 250cc throttle touchy
In first gear if I let off on the throttle quickly and then apply some throttle the bike jerks. Does anybody know how to make the throttle tamer?
01-28-2023, 04:48 PM | #2 |
Often what you're describing is caused by drivetrain slack. Check that your chain is properly tensioned. You might also try loosening the throttle cable a bit. GL
22 Templar 250 |
01-29-2023, 02:29 AM | #3 |
Touchy throttle
I have the Lycan 250cc and I have the same problem. Searching throughout the internet a bunch of replys say that there is too much slack in the throttle. I checked the manual and the slack should only be 2 to 6 mm for the bike. I will also check the slack in the drive chain. I found a couple of things that need readjustment. I guess they just slap the bikes together.
01-30-2023, 12:58 PM | #4 |
You got it,the faster built. Will make more money,China thing.
02-09-2023, 07:36 PM | #5 |
After adjusting the slack in the throttle I can start in first gear from a dead stop with no jerking. When I shift from 1st to 2nd and letting out the clutch it has some jerking. Not much but still not smooth. Is it just me? Do I have to get used to it? I had a Honda Goldwing and there was no jerking.
