09-13-2018, 04:40 PM | #1 |
Replacement Kick Start Arm/Lever
Anyone can recommend a kick start lever upgrade for the Hawk/BSR/TT250?
Looking to save some weight as the existing unit is substantial. I do mostly nasty dirt trails in the desert. I might even just take it off and do push starts if I need to.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
09-13-2018, 04:51 PM | #2 |
This one is aircraft grade 6061 T6 aluminum https://www.amazon.com/dp/B0055DPMFK...v_ov_lig_dp_it
09-13-2018, 05:11 PM | #3 |
Thx, but I think that one shifts but doesn't fold out of the way like the kick start lever?
09-13-2018, 05:21 PM | #4 |
Sorry, It's been a long day. I swore I read shift lever. I'll see what I can find.
09-14-2018, 11:11 AM | #5 |
What is the shaft size?
09-14-2018, 04:47 PM | #6 |
09-14-2018, 04:50 PM | #7 |
That's what i'm thinking. I wasn't sure if his was the same as the Hawk. If it is then any kick start off a CRF150 should fit. Aluminum one get a little pricey though.
09-14-2018, 05:18 PM | #8 | |
the saving from a kick is so small and it's low weight..he needs to find something higher up that has a saving that is noticable... my boys CRF150f broke it's kick so I put a chinese one on we went though 2 of them.. but they were like $20 each where the standard Honda one was around $170... ..
09-16-2018, 11:55 PM | #9 |
Yes the shaft is 16mm... Thx I will start looking for CRF150 parts. Might be more bling than weight saving at this point, or I might just leave it off the bike.
