Old 08-17-2015, 01:00 AM   #1
detours   detours is offline
detours's Avatar
How to install your 13T sprocket
I installed my 13T countershaft sprocket today, replacing the stock 14T sprocket. This is a great way to widen the powerband of the engine and make your gearing more usable, especially on hills. It also gives you a usable 6th gear.
The swap was very easy, even though I had never done it before.
Tools Needed
  • 8mm socket - countershaft sprocket cover bolts
  • 13mm socket - outside axle locknut
  • 13mm open ended wrench - inside axle locknut
  • 18mm socket - left side axle bolt
  • 19mm socket - right side axle nut
  • 30mm socket - countershaft sprocket nut
  • Large flat blade screwdriver - countershaft sprocket safety washer
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
