Last ditch effort to fix HS200GY
Blame my lack of prior research and a shady dealer on this one. I have a bike that on all legal paperwork shows that it is a Roketa DB-07A (RSX-200E). However, in looking at Roketa's web site and various pictures (oh yeah, and the owner's manual), it isn't a Roketa.
I broke one of the valve springs, and the Roketa replacement valve is not the right part. A bit of research and it turns out I have a Viva branded HSun HS200GY. The engine is similarly branded with the Viva brand, but labeled with the HS163FML model that indicates that it is an HSUN 200cc motor. I have looked everywhere now, the manufacturer, motopartsmax.com, motosportparts.com, etc., and I can't find anyone that sells a new valve and valve spring set. I can but the entire motor, or nothing. So I am now at my wits end, I'd like to know if anyone know of a parts dealer that can sell me the parts I need? If not, then I will have a very slightly used HS200GY with non-working motor with only 457 miles on it for sale or part out very shortly. Thanks, Dennis |
This is easily do-able. I forgot the dealer, someone will chime in soon.
Here you go, found it. $28. ![]() http://www.motopartsmax.com/index.ph...ducts_id/11396 I had an HSUN, BTW. Pretty good bike.
Happy to serve. |
Nice find, Doc!
![]() Spud ![]()
That is where I bought my first kit from, and it didn't work. This kit says that it is for the Loncin engine only. Mine isn't Loncin that I know of and I hate to waste a second $35 for something that wont work. Is Loncin who makes the HS163FML? I notice that Lifan makes an engine that is 163FML, but looking at their pictures and talking to Phillip at MetricPartsHQ.com, this HS163FML is most certainly not a Lifan.
Sorry for my ignorance, I really have been researching this a long time. |
Can you measure one of the valve springs and let us know? I'll compare it with some old XR200 springs I have if you wish. Honda springs will be easy to find if they're a match.
Be specific about ID, OD and free height. Installed height would be a bonus. BTW, how on Earth did you break a valve spring? 8O
[quote="bonus.
BTW, how on Earth did you break a valve spring? 8O[/quote] I was wondering that also 8O
Is the 163 a pushrod or OHC engine? I would be surprised if the lifan springs didn't fit.
If OHC the honda ones may work. Allen
Pushrod. The latest Chinese technology.
Happy to serve. |
That is what thought. Same as my lifan. I think that some of the older honda atc engine might have been pushrod, but I am not 100%. Just a blip I caught from another post at one time.
I would check again with metric parts and see if those are pushrod or OHC springs. Allen
I have the same motor hs163fml. measured the valves 27mm out / 32mm in
i also bought the bike from powersportsmax, and ordered parts from motopartsmax that did not fit the bike when the website said it would. I dont know about the loncin valve assy. they sell because it doesn't have dimensions. But i did find these http://www.motorparts4less.com/products.php?id=562 that match the dimensions i have so far. Nothing "appears" to be broken, i get about a mile down the road then rpms start droping up and down, backfiring, will die if i don't stay on the throttle, eventually does die and wont start untill i adjust the valves again.. A freind suggested the valve springs may be getting hot then loosing some strength to hold the valve closed, i dont know, but it does say in the manual to Replace valves every 2,000K it has almost 3,500. so guess i'm gona order this assembly and find out..
http://s964.photobucket.com/albums/ae124/08hsun_photos/ |
#11 | |
#12 | |
You do not need to replace valves every 2000k - they should last 10 to 20 times that. Frog |
#13 | ||
#14 |
I'd replace the base gasket before going after the valves personally. You have an air leak that prolly causes it to run extremely lean to the point of not being able to have the correct air/fuel mix.
#15 |
I agree
For future reference the valves are: Intake: 32mm base, 92mm length, 5.46mm shaft width exhaust:27mm base,91mm length, 5.46mm shaft width |
