07-27-2019, 03:52 PM | #1 |
3150DX-2 Muffler and tail pipe
I have a 2012 coolster moontopz-150 atv, 3150dx2 150cc quad. The problem i'm having is getting a tail pipe . when i go to order it they can't find it. has anyone had this similar problem trying to buy a tail pipe for this model of quad.
07-29-2019, 08:21 AM | #2 |
I have the same ATV. I'd be willing to bet the exhaust system on most of the 150cc ATV's will fit. The TaoTao ata 150d is very similar to the coolster. They give you measurements so you can check for fit. https://www.vmcchineseparts.com/coll...ao-ata150d-atv
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-24-2020 at 03:49 PM. |
01-24-2020, 01:24 PM | #3 |
Have you been able to find a replacement that works with your ATV? I ran into the same problem and it's proving almost impossible to find something that works.
