Hawk Hack
Backstory:
I have had a dusty velorex 562 sitting in the back of my garage for the past 3 years. Winter is around the corner here in Wisconsin and I was bored so I decided to try mounting the Velorex to my hawk! I still need to: - change out the rear sprocket from a 43T to 51T - tune steering geometry - do wiring for sidecar lights - figure out the sidecar aux brakes. All in good time I suppose! For now I am just enjoying the ridiculousness of it all at a max of 30mph ![]() Behold: ![]() ![]() |
All I can say is
#3 | |
I love it! I really need to find a hack.
Find or weldangrind?
That was the exact sidecar rig I was looking for to use with my V Star 650 Classic.
Hmmmmm! a little square tubing, tire and rim, Sheet metal work, I think I could fab one up.
You've peaked my interest in this. Can you share some pictures of the mounting points?
#9 | |
http://www.velorexusa.com/Instructio...chment_kit.pdf http://www.velorexusa.com/parts.shtml And here's a link to more velorex documentation: https://drive.google.com/drive/folde...2c?usp=sharing If you really wanna cheap out, you could fab this up yourself as well (probably). Here's the best picture I've got at the moment, I can take better pictures if you need them when I get home. Just tell me what you want. Also I think you have my number, so feel free to text with questions too. ![]() |
Thanks, I would more than likely fab up everything myself. You know me, I'm a cheap bastard.
All you guys need is the uber app and ret to go
What will they think when you pull up for the pick up with that
#13 |
Good to see a dirt hack...
well done.... I started building this for a couple years ago but put it on the back burner as i had no room.... it is one "well the main reason" I have built the new section onto my shed... so I can finish it... This unit will go on the XT660R... the bike will still beable to lean... As the bike leans the car steers into the corner by useing a bigger arc ratio on the front mount than the rear.. May have gone a bit overboard on the suspension but it has a quickly adjustable ride hight/leveling for diffrent loads... shock has adjustable spring preload/ rebound damping & compression damping.. HERE===> http://advrider.com/index.php?thread...#post-30012877 My sig on ADV has a link to my first one... a cargo leaner on a XR250 built a few years ago now.. I am surprise you are not using a sub frame to spread the load.......pitty the exhaust is in the way so you couldn't get a straight alinement on the top rear mount... keep a eye on it as it will want to turn.. see you havn't got alot of lead on the car wheel so your steering should not be to heavy ?.. sorry about the link to ADV rider.. but photobucket won't let me post the pics... .
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 10-17-2017 at 04:06 AM. |
#14 |
Wamey, caught your video on FB.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-18-2017 at 07:46 AM. |
#15 |
Pete, nice work on the frame.
