Go Back   ChinaRiders Forums > General > News, Support, & Feedback
Old 08-08-2018, 11:38 AM   #1
Mstraight   Mstraight is offline
DongFang 4 seater Electrical problems
I have a DongFang 200CC 4 seater. just one day the engine would not crank from key. If I turn key on and then jump the Starting Solenoid, the cart runs. I replaced the starting solenoid, still same problem. I need to see if I apply 12v directly to the control lead of the solenoid, if it will start, indicating an issue between Key and solenoid. However, now I am am see the headlights DIM when at idle, really bad. at one point the headlight cut out under full throttle. Any ideas,,,, loose Ground issue??? Volatge Regulator???? CDI????
Thanks for any help
Matt
