06-09-2018, 02:21 PM | #1 |
Wheel alignment
Hello Guys, i would like to ask you How could i alignment the front wheels on my Rx3? When is my handlebar straight then the wheel is little bit turn right...
Many thanks |
06-09-2018, 09:44 PM | #2 |
It sounds like your triple clamps are twisted or either the forks are twisted in the clamps. You'll need to get the weight off the front wheel, not off the ground. Loosen the triple clamp fork bolts. Set the wheel straight and retorque the bolts. If the axle bolt is bent, the wheel may not line up properly. Check the RX3 thread for the proper torque settings.
