Old 09-03-2017, 06:25 PM   #1
NickThrash   NickThrash is offline
HELP HAWK Oil Res. Bolt Broken
Alright guys I'm in need of some serious help here.. I was going to take my HAWK on a ride for a bit and before leaving i noticed my mileage, since the last oil change, being pretty high so I said "Ah, might as well change the oil before I ride. It will only take 10-20min and ill be done".
So I drain the oil and begin to start putting the Bolt with the O-ring back on and as i get it tight i give it a crank (By hand) and all of a sudden it's loose. Initially I thought I had stripped the bolt, but as soon as I look I see a giant crack on the bolt.. I have no idea where to get a replacement. txpowersports doesnt have it on their list of parts and RPS has been a real trouble to get a response from For quite some time now. Im not even sure what the exact name for the bolt would be (Oil Pan bolt or Oil Reservoir Bolt, or Oil Drain Bolt?) Or if I could even find a replacement for it that isnt from the manufacturers I wouldnt know where to start..
Im starting to get real tired of the hardware on the HAWK. ive broken so many bolts, and most of the time its meaningless, easily replaceable bolts. But this is a serious part of the bike?! My bike is useless right now because of this one bolt...
Any guidance is appreciated..
Old 09-03-2017, 07:26 PM   #2
clark   clark is offline
clark's Avatar
Boy is that an awe-shucks! I'll be following your repair (just in case I run into this.)
Magician 250 (9/2016 engine label)
Kawasaki 650 KLR
Honda 1300 VTX
Qlink XF200
Old 09-03-2017, 07:47 PM   #3
lostforawhile   lostforawhile is offline
what size socket fits on there? it looks like the same drain plug bolts that fit scooters
Old 09-03-2017, 07:50 PM   #4
I use a 15/16 Socket (24mm)
Old 09-03-2017, 07:53 PM   #5
Mudflap   Mudflap is offline
Probably the same as any pit bike engine so there should be lots of them on eBay. The CG engine on my Lifan uses the same one as the horizontal Lifan.
BTW: A torque wrench may be a good idea.
Old 09-03-2017, 08:11 PM   #6
silva   silva is offline
silva's Avatar
http://www.ebay.com/itm/Oil-Screen-F...?hash=&vxp=mtr
Old 09-03-2017, 08:16 PM   #7
Originally Posted by silva View Post
is that the same size?? it looks a little bit smaller. Just want to be sure before I buy
Old 09-03-2017, 08:54 PM   #8
silva's Avatar
It fits, use (19mm) socket instead of (24mm)
Old 09-03-2017, 08:58 PM   #9
Hey thanks so much man! I was looking all over and couldnt find anything that would give me a definitive answer on if what i was finding was the right size, or i found bolts that were obviously WAY too. Thanks again, you're a life saver.
Old 09-03-2017, 09:05 PM   #10
JeremyC   JeremyC is offline
It's the same one that goes on a honda 200 3 wheeler if that helps. They're identical.
Old 09-04-2017, 02:20 AM   #11
pcspecialist   pcspecialist is offline
Take it into a Honda parts store, they probably have one on hand.
Old 09-04-2017, 03:48 AM   #12
You can also go this route. The TT250 has been a wonderful parts source for little things like this on my Hawk.
Part #12, and it's a whopping $1.95 http://www.cscmotorcycles.com/TT250-...LOCK-s/325.htm
Part #7 will be the O-ring for it at a massive 65 cents. Part 8 is the spring, and 13 is the screen, but you shouldn't need those.
So, $2.60 plus whatever shipping will cost.
Old 09-04-2017, 04:07 AM   #13
pete   pete is offline
pete's Avatar
looks at same as the oil drain on the Honda CRF150F....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-04-2017, 08:21 AM   #14
humanbeing's Avatar
Honda parts #: 12361-383-000
Old 09-04-2017, 04:10 PM   #15
are you saying you dont think it will fit? because i just ordered that one off ebay that he gave me the link to...
hawk 250
