Old 03-17-2017, 10:22 PM   #1
Musictrek   Musictrek is offline
Musictrek's Avatar
Hawk lightbulbs
I had a turn signal bulb go out. I tried three local autoparts stores even a cycle shop and they did not have the bulb. Yay for Ebay! I got ten of these for ten bucks. I tried one and they do work! The glass shape is a little different, but they work as normal. Remember, the pins on these bulbs are off set of each other. Also, the front halogen headlamp is a HS1 35/35 watt bulb. There again, no local store in my area had that low of a wattage bulb. They had HS3 and HS4 I may go LED, but this is on the cheap right now.
Old 03-17-2017, 11:49 PM   #2
humanbeing's Avatar
BAU15s vs BA15s (1156)
Pliers (files...) & solder iron is ur new friend if can't find the offset BAU15s locally
HS1 vs H4: https://en.wikipedia.org/wiki/User:KDS4444/HS1_bulb | https://translate.google.com/transla...3D1&edit-text=
Old 03-18-2017, 01:31 PM   #3
Musictrek's Avatar
That's good information!
Old 03-28-2017, 10:04 AM   #4
Musictrek's Avatar
Hawk brake light bulbs
I found these online for the hawk
