Old 06-14-2017, 04:11 PM   #1
wamey   wamey is offline
wamey's Avatar
Thumbs Up Hawk Fork Brace Mod
Here are the mod pictures:
http://imgur.com/a/PamSn
I ordered this harley brace and drilled holes in it:
http://www.ebay.com/itm/252955960539
All in all I'm happy with the front suspension being a bit stiffer! I only have an hour of riding on it thus far so I'll get back to you all once I've field tested it a bit more!
Old 06-14-2017, 04:43 PM   #2
Rangerscott   Rangerscott is offline
Thats a poor design.
https://www.google.com/search?client...0XAZEQvwUIXigA
Old 06-14-2017, 04:47 PM   #3
wamey's Avatar
Originally Posted by Rangerscott View Post
Both designs are used to brace front forks, scroll down on your search...
The reason the aluminum clamp is more difficult here is because the tire/wheel would interfere with a straight across clamp so you'd have to machine a much larger block of aluminum.
Old 06-14-2017, 05:27 PM   #4
You would put it up higher on the forks.
Old 06-14-2017, 05:32 PM   #5
I've had three similar to yours on my old, stripped Yamaha Enduro's I used to race (way back when) and there was a serious difference in front end rigidity.
I think yours looks cool and it appears to fit very well.
Old 06-14-2017, 05:37 PM   #6
wamey's Avatar
That would interfere with suspension travel, and not brace the parts I want braced.
The reason I want the lower part of the fork assembly braced is because these were rotating ever so slightly, allowing the wheel to turn about +/- 2 degrees from the handlebars. At higher speeds on uneven ground this manifested as a slight "speed wobble". The brace I used prevents lower fork twisting which helps to minimize wheel flop.
Old 06-14-2017, 05:39 PM   #7
Nice job. Looks like the only option you have. The other style wouldn't work because the 21" wheels is higher than the lower fork housing. No way to mount it.
2020 Kawasaki Vulcan S
Old 06-14-2017, 08:53 PM   #8
ben2go   ben2go is offline
On thin forks and light bike, anything to stiffen the front end is helpful.
Old 06-14-2017, 10:01 PM   #9
I am still on a quest for a clamp style that may work, There are a couple of possibilities, but if they don't pan out then I am going this route. Many older hondas used a similar idea to integrate a fork brace with the front fender, and trust me it makes a difference! For 20 bucks and some time drilling a couple of holes, can you really complain?
Old 06-15-2017, 10:12 AM   #10
This is, by far, the biggest benefit to USD forks. With the fat tubes being in the clamps and very long, it is far more rigid than a standard fork.
Old 06-15-2017, 12:23 PM   #11
Good idea! The TW200 uses a similar brace as a fender mount, to contend with skinny forks and a 4.00-18 front tire.
Old 06-16-2017, 03:49 PM   #12
elevatorman   elevatorman is offline
I like this idea and really appreciate the poster.
Immediately I went over and ordered one for my Hawk 250.
Whereas it might not be the best it is certainly something and
very affordable.
Old 06-17-2017, 09:21 AM   #13
I wonder if they produce them in-house? I just asked if I could get one without the mounting holes, preferably without the ears too. If they get enough requests, maybe they'll say yes if they initially say no.
Old 06-17-2017, 09:35 AM   #14
Kdburtch   Kdburtch is offline
awesome write up, thank you. Does it completely clear the knobbies, or is there some rub?
Old 06-17-2017, 02:56 PM   #15
It clears with plenty of room around the tire. Take a look at his pictures and if you go to the 5th one down you see a straight on shot showing plenty of air gap around the tire.
brace, front forks, hawk, suspension
