Old 04-19-2015, 09:54 PM   #1
maverickfe   maverickfe is offline
Hi Bird
I have an 2006 250 Hi Bird when I pull the clutch lever it seams that it don't go far at all when I look at the lever on case. I looked at the cable and lever an it looks like I need a new one does anyone know where and what one I should get and how to adjusted when it comes time?
Thanks
Old 04-20-2015, 11:24 AM   #2
Before buying new parts, have you tried lubricating the cable? I use a cable luber and Maxima Chain Wax on cables. Here's a decent luber: http://www.ebay.com/itm/Motion-Pro-C...98f9d5&vxp=mtr
Lubricating the cable can make all the difference.
Once the cable is lubed, shoot for about 1/4" of freeplay gap, as measured between the hand lever and the perch it is mounted on.
Old 04-20-2015, 12:16 PM   #3
Thanks no I have not lube it yet looks like the last person half ass it but I will try that. I will post some pictures of it tonight.
Old 04-20-2015, 09:54 PM   #4
Here are a few pictures of my cable .
Old 04-21-2015, 01:00 PM   #5
The end of the cable housing isn't sitting in the adjuster at the hand lever. Did you pull the housing out for the pic? Also, the adjuster is turned all the way in.
Set the cable housing inside the adjuster, and back out the adjuster to keep some tension on it. Try to establish about 1/4" of freeplay between the lever and the perch.
Old 04-21-2015, 02:50 PM   #6
No that's the way it's been ever since I bought it. It just feels like it's not doing anything when I squeeze it and put it in gear it just jumps. As you can see he had a bolt in the handle that's not the right one.
Old 04-26-2015, 09:27 PM   #7
Well I oiled the cable this weekend it pulls smoother then it did tried to adjust it but it will only move the clutch a small amount I thinking I need a new cable like to get a new handle too what is the wiring coming out of the handle for and where would be a good place to get the parts at? Here are few pictures first is how far it moves before it grabs the 2nd is all the way. Hope you can tell at the end of the cable how far it goes by the pictures.
Old 04-26-2015, 09:32 PM   #8
Adjuster's Avatar
It also appears you have a considerable mount of adjustment available where the cable attaches to the motor case before the shift lever. But it does look like you need a new cable given the condition of that rubber boot.
Old 04-27-2015, 11:30 AM   #9
I was going to say the same thing. Try backing out the adjuster that is above the clutch cover on the engine.
The wire is a switch, and it's designed to not allow electric start unless the clutch is pulled in.
