09-28-2019, 06:35 PM | #1 |
Fuel Line Question
Does anyone know the OD/ID of the fuel line that fits our petcock and carbs? I went to the part store but nothing looked right. Plus everything was reinforced for pressurized fuel systems.
Thanks |
09-28-2019, 06:44 PM | #2 |
I used 3/16 ID. I had to go to a bike shop for it but I suppose any small engine repair shop should have it. Get a few feet you won’t regret it. Also those spring clamps to keep them tight. The outside of my line is marked Oregon if the manufacturer helps. I think it’s chainsaw fuel line.
09-28-2019, 07:22 PM | #3 |
Awesome, thank you
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
09-28-2019, 07:23 PM | #4 |
I use 3/16 standard braided fuel line as per megadan. I have about 45 ft, it's not high pressure. Should be able to get some locally, if not I can send you some.
09-28-2019, 10:33 PM | #5 |
I hit up the local lawn and garden section or tractor supply and grab a small coil of clear lawn and garden 3/16 fuel line and a small filter for mine. Works like a charm.
Otherwise, 5mm fuel line is also the correct size,
09-29-2019, 07:35 AM | #6 | |
