09-16-2019, 04:41 PM | #1 |
high lift cam for CG engines?
does anyone make either a higher lift cam or higher ratio rocker arms for the CG engines? is it not possible due to the single lobe design?
09-16-2019, 09:49 PM | #2 |
Yes they do make higher lift cam and higher ratio rocker arms for the CG engines. At least in South America
09-17-2019, 09:35 AM | #3 |
any chance you could give me a link to a site? I can't seem to find any on a google search.
09-17-2019, 11:13 AM | #4 |
I've looked into it too, the Brazilians seem to be the most into hot rodding them, and I tried to contact them on a site, with no luck. I looked at something like this: https://motos.mercadolivre.com.br/pe...ao-cg-vareta-a
09-17-2019, 11:21 AM | #5 |
I suspect they're getting those parts from China. The trick would be to figure out if it's on Taobao.
09-17-2019, 12:59 PM | #7 |
I like your thinking.
09-17-2019, 03:52 PM | #10 |
Same here with my 200x. I miss that bike.
09-17-2019, 11:20 PM | #11 | ||
When it comes to vehicle mfg in South America, Brazil is #1 then is Argentina. If we take Latin America, then it's Brazil, Mexico, Argentina. Honda, Yamaha, Toyota did invest a lot of money in SA. Toyota mostly in 4 wheels vehicles, while Honda and Yamaha mostly in motorcycles. So there are mfg that make custom parts from 0. Also you have tuned china stuff. For example, right now i'm starting to buff out my chonda. -alloy rims, locally made, a bit better than the chinese ones and cheaper -Big bore kit, is made in Taiwan but resold under an Argentinian brand, the gaskets are made here. -New Springs for the front fork, national made for chondas with different spring rates. -Handlebar with raiser Brazilian made. -Silencer, national made cloned from fmf. -Cam brazilian made. -Alloy skid plate national made. Quote:
Just to give you an idea. I paid 20 usd for the alloy skidplate |
09-17-2019, 11:36 PM | #13 |
Tako you need to get on this..
09-17-2019, 11:47 PM | #14 |
I wonder if NZ would feel so inclined to chime in here.
09-18-2019, 02:53 AM | #15 |
I was thinking something like this: https://produto.mercadolivre.com.br/...2-43a2070f4660
And this: https://produto.mercadolivre.com.br/...2-43a2070f4660 But I wouldn't need the pushrods. |
