09-27-2019, 01:11 AM | #1 |
Bike Recommendations?
I'm looking to buy my first bike in the spring. I definitely want an automatic transmission. I've been looking at the Vitacci Rocket 150cc but am worried it isn't powerful enough for me. I weigh 240lbs and I would like to reach a top speed of 65-70mph. I want something in the style of the Rocket, not sure what that's called if it has a name. I'm really new to this, just started looking this week and found this forum so I figured I'd see what you guys have to say. Remember, automatic trans, don't try to convince me otherwise. Thanks.
09-27-2019, 03:54 AM | #2 |
Vitacci doesn't list power specs for the bike, but as long as the sprocket combination is capable, it isn't unrealistic for a 150 single on a small bike to be able to hit 65-70mph maxed out. If said bike can do so out of the box is a different question. They list the top speed as 50mph, so what the limiting factor there is hard to say. The Lifan KP Mini (150cc grom clone) can reach those speeds, so using that as an analog it is possible. Wanting an automatic/semi-auto is going to be a very limiting factor in bike choices. While I won't try to convince you to learn a manual, I would say that it would be worth learning at some point in the future once you are comfortable with riding. Good luck!
09-27-2019, 07:55 AM | #3 |
Welcome aboard! Venom carries a 250cc full auto. https://www.venommotorsportsusa.com/...16080693657702
Belmonte https://www.belmontebikes.com/produc...ully-automatic and Superiorpowersports Aka the Falcon. https://www.superiorpowersports.com/...0mc-falcon.htm
09-27-2019, 09:50 AM | #4 | |
09-27-2019, 11:57 AM | #5 | |
Thanks for those suggestions but I've looked at those already. I don't like the full front fearing look. I'd like to find something with an open frame or minimal body paneling. |
09-27-2019, 12:04 PM | #6 | |
09-27-2019, 04:08 PM | #7 |
Ok, so after learning more about the engine on the Rocket, I see that there are tons of upgrades available for the 157QMJ GY6! I think I'm going to go with the Vitacci Rocket 150cc unless anyone has a compelling argument against it for something else.
05-22-2021, 09:26 PM | #8 |
Automatic Motorcycle > 250cc
Looking for Automatic transmission Motorcycles that are 250cc or above. Please let me know if there are dealer links for a fully assembled motorcycle.
