06-25-2018, 10:04 PM | #1 |
Fork squawking
When sitting on the bike, rolling backwards etc you can hear a bit of a rub/squawk/knock noise from the front shocks. You can feel it a little in the bars as well. Makes me feel like a little grease on the silver portion that slides up into the gold would help? Thanks in advance.
06-25-2018, 10:36 PM | #2 |
i would take it all part an greace the crap out of it ,they dont put much greace on things from china after those 16 hour days an replace the fork oil ,you should have 2 to 4 bearings in your steering post,not sure wich bike you have but the sway bar bushings need greace too ,as well as the wheel bearings ,get a couple pounds of it
06-26-2018, 05:36 AM | #3 | |
Never never never never etc.... you get the idea... put grease on the fork sliders.... dirt / grit / dust will stick to them and become like grinding paste it will migrate past the dust covers/ wiper seals and end up going though the fork oil seals... And it won't do the internal fork bushings any good either... ..
06-26-2018, 06:00 AM | #4 |
What Pete said x2. Plus, how do we know its the forks? If the forks squeak going backwards, they should do it sitting still or going forward, basically any fork movement. I would suspect something else is at play. Get the front wheel off the ground and spin it slowly in the direction of reverse and see if you can recreate it.
06-26-2018, 12:42 PM | #5 |
there all ideas for the safety i longevity of your bike an what i said ,do we just got a case of lets repeat what the other guy said on this forum,if you dont have the skills to take the forks apart an do what i said find someone who can do it guess we all seem to know it all hear right ,or not
06-26-2018, 02:13 PM | #6 | |
06-26-2018, 04:02 PM | #8 |
yep high pitched squeak is coming off the rotor! lets take the engine apart just to make sure.
06-26-2018, 05:33 PM | #10 |
It could be a number of things.
1. Does is make this noise if you rock it back and forth when you have the front brake applied ? if so could be lose brake caliper and/or steering column. I've had a bolt loosen on the brake caliper that made a similar noises. 2. If it turns out to be the brakes making the noise you can clean the rotor and pads with a brake cleaner. You may still have film of the shipping corrosion protection oil on them. or what ever they use.
06-26-2018, 05:36 PM | #11 | |
You Can't....
06-26-2018, 06:08 PM | #12 |
I'm just curious if it is a point of concern is all.
It does it just sitting on the bike, you can't hear it with the engine running. Brake is irrelevant and there is no high pitched squealing. Sitting on the bike walking it backwards across my crap driveway to park is where it's most annoying. A very short and dull squawk noise like rubbing your thumb on a dish to feel if it's clean is the best I can describe the noise. At the very top of the shocks un-compression there is the knock that can always be felt in the bars. Rolling over terrain or stationary is the same knock feel. It's the exact opposite of the rear shock, it clunks at the bottom and squawks when you get off the bike. Is there anything we can do to the rear stock shock to improve performance? That thing is a joke |
06-26-2018, 06:47 PM | #13 |
Id worry about the steering head, "there is a set of holes in the side of the steering head big enough to squirt in some oil". for a temporary solution. Id recomend taking that apart and adding some marine grease, mine was dry as a bone when I got my bike.
If it is the forks maybey they forgot to put in the fryer oil at the factory? Dry stuff will chirp for sure. it's the death moan. I wonder now if those holes were for a info plate of some kind, Hmm weird. Use a bendy straw spray lube and you could hit the top bearing too. |
06-26-2018, 07:08 PM | #14 |
Sounds to me like it may be low on fork oil enough that the fork seal is dry rubbing. Did you check/change the fork oil during assembly?
06-26-2018, 11:29 PM | #15 | |
