05-21-2020, 10:25 PM | #2 | |
Assuming float height is set correctly, the next thing I would check for is that you don't have a vacuum leak. That would play hell with all of the mixture settings. Also, what mods, if any on the bike?
05-22-2020, 12:04 AM | #3 |
Dan correct me if I'm out of touch but my hawk was shipped with tight valves and that needs ro be checked first, right?
05-22-2020, 12:07 AM | #4 |
Also a possibility, yes.
05-22-2020, 01:17 PM | #5 |
I have two hawks both run 40 / 110 , two turns and two washers . maybe a little lean . ive had this tbr7 for a month ,still doesn't run.
it can with a broken primary jet. had to buy a new carb . |
05-22-2020, 02:17 PM | #6 |
Ok I checked the float level .good. sprayed it down , no vac leak. The only mod is cat removed. Ok 45 / 110 jets ,third slot on needle . will not run in the middle ..
05-22-2020, 08:37 PM | #7 |
Ok im going with 40 /110 adjust the needle up to the forth slot . Starting there again. I took the carb all apart and cleaned .Hope this works
