Old 06-17-2011, 02:28 PM   #1
hunter04416   hunter04416 is offline
Hi-Bird qh-200st atv, I need some help getting it to start
Hello to all,
I am a new member, i have recently got a Hi-Bird qh-200st atv. Its in great shape, but the last owner said it will not start. They put a new battery in and thats about it. What should be my plan of attack to get to start. As of now, it will not turn over at all. I bought a new battery too. I am thinking maybe wiring, cdi box....any ideas?
Thanks
Old 06-17-2011, 03:39 PM   #2
makenzie71   makenzie71 is offline
I have a 250ST! You're the only other HiBird quad owner I've seen lol.
Define "will not turn over". Some people say that and mean it won't fire, but cranks. Will it crank at all?
If it does crank, do you have spark? Pull the spark plug wire off and use a screw driver or another spark plug. Hold it close to the exhaust and crank the motor to see if there is a sparking going on.
No spark, almost certainly means CDI.
If it does not crank, do you mean just by pushing the button? Try holding a screw driver across the terminals of the starter relay and see if it'll crank tha way.
Old 06-18-2011, 12:34 PM   #3
Well when i push the start button, nothing happens at all. Battery is fresh and charged. I will try the starter trick
Old 11-01-2012, 06:50 PM   #4
Wes   Wes is offline
I just purchased a used hi-bird QH200ST. Does any one know where I can find replacement parts for it?
Old 11-01-2012, 07:03 PM   #5
midlifekrisiz   midlifekrisiz is offline
i usually start with something like this when i am searching for answers
http://www.google.ca/search?q=hi-bir...w=1280&bih=709
or ask this guy http://www.chinariders.net/modules.p...profile&u=2112 muhuhahahahaha ha :twisted:
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div>
Old 11-01-2012, 09:14 PM   #6
Welcome Wes!
What sort of parts are you after?
Old 11-02-2012, 12:47 PM   #7
Wes   Wes is offline
I could use a new tail light. But I'm sure something will eventual brake or ware out. It makes me a bit nervous when I can't find a online part store, that deals with hi-bird atvs.
Old 11-03-2012, 03:11 AM   #8
Most of us opt for aftermarket stuff, like the Edge II tail light. eBay is your friend for most parts. Search for generic terms, like "dirt bike muffler", and you'll likely find what you're after.
Old 11-03-2012, 02:00 PM   #9
Wes   Wes is offline
Thanks for the advise, I truly appreciate it.
Old 02-18-2013, 02:13 PM   #10
migue1760   migue1760 is offline
migue1760's Avatar
Hey i have a quad similar to this but its water cooled, i havnt seen anyone with a chongquin huansong quad?
Old 02-28-2019, 10:39 PM   #11
Makeitoffroad   Makeitoffroad is offline
Question Hi-bird qh200st
Does anyone in this forum have a wiring diagram for a Hi-bird qh200st. The previous owner had unplugged a few wires and not sure where they go. The quad will turn over, but no spark. It has a brand new cdi. All I need is either advice or a wiring diagram. Thanks, Makeitoffroad
Old 03-19-2019, 02:32 PM   #12
Tao125f1   Tao125f1 is offline
The factory cdi should be DC if they replaced it with AC cdi. seen that happen before.
