Old 02-09-2022, 12:55 AM   #1
Fish_Master   Fish_Master is offline
Tbr7 won’t crank over
Alright so I have a 2021 tbr7. I have been riding it for a while with no problems. Recently I noticed it is having trouble starting in the cold. I live in Texas and we recently has some freezing temperatures. The other night I couldn’t get it started. I tried to start it for a bout an hour. The electric start just wasn’t doing it. The kick start was getting it started for a few seconds then it would sputter and die. I tried to jump start it with my car. Probably a real stupid idea because not it’s completely dead. Like the battery has zero charge and lights won’t turn on at all. Pretty sure I blew a fuse or shorted something out. Any help would be well… helpful.
Old 02-09-2022, 04:21 AM   #2
Update I for sure blew a fuse. I changed it and the battery was fully charged and cranked over but the bike wouldn’t start.
Old 02-09-2022, 07:34 AM   #3
Are you using the choke when you are starting it?
2020 Kawasaki Vulcan S
Old 02-09-2022, 08:49 AM   #4
TxTaoRider   TxTaoRider is offline
Did you adjust your valve lash? A symptom is hard starting when cold. Also get rid of the stock spark plug if you're still using it.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 03-02-2022, 06:49 PM   #5
A1R 250 bob   A1R 250 bob is offline
A1R 250 bob's Avatar
If you still are using the stock carburetor and haven't changed the main jet, the settings are exceptionally lean. I have an older TBR7 and re-jetted it to a 110 and usually don't need the choke to start when it is warm, but in cold weather the choke is needed. Perhaps a bit of starting fluid may get it going, provided you have spark.
Old 03-04-2022, 08:30 AM   #6
kyle   kyle is offline
Adjust your pilot jet and you won't have that issue. You'll have trouble finding the pilot for the stock carb but the clone has pilots available on amazon. https://tbr7.com/upgrades/fuel-system/
