03-06-2017, 06:56 AM | #2 |
i finally got mine installed yesterday, it works perfectly and looks awsome, i am gonna cut a spacer for the left side mount bolt to level it out you can see that i have a few old washers in there right now. and yes the mileage is still at zero, we had a high temp yesterday of 19 so the test ride got postponed for a warmer day. |
03-06-2017, 12:33 PM | #3 |
Wow! That's the furthest off i have ever seen! Most level up with 2-3 washers. Double check your grommets are not smashed. They should be loose a bit. Use loctite on the cluster studs..... |
03-06-2017, 01:51 PM | #4 |
the grommets are ok and i put loctite on every nut and bolt i could find on this bike. I ended up with a 3/16" spacer behind the mounting bracket. when i get a few minutes this week i will cut a tapered spacer to cover the entire back of the bracket. |
03-07-2017, 02:23 AM | #5 |
How much are you selling them for? I ordered a hawk, but APSC told me they upgraded me to the enforcer. Once that arrives I'll have to see, but I'm sure I could make this hawk upgrade cluster work on the Bashan Enforcer.
Does it plug into the hawks harness directly? Or do you have to run your own wires for the tach signal, etc? |
03-07-2017, 02:47 AM | #6 |
i think the enforcer has the digital dash
