04-17-2019, 09:24 PM | #1 |
Which carb for upgrade?
Hey all,
2018 Hawk 250 - I searched the forum but couldnt figure out if its the VM26 or VM30 Mikuni carb that some of you have replaced the stock carb with? Ive seen prices from 30-90$ - anyone got a link or two? How about the jet kit? I plan to do the airbox mod, and Ive bought the aftermarket exhaust. With this carb upgrade, I do not have to change the stock rubbers on in and out? Thank you for any info! |
04-17-2019, 11:26 PM | #2 |
Also,
I am looking to replace the rear brake light to an LED. Will this cause electrical pulses (like on my old Kawi's)? Does anyone know which socket/led bulb to use? Thanks again, I tried searching but couldnt find the answer. |
04-18-2019, 12:04 AM | #3 | |
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim Last edited by Jeff Richardson; 04-18-2019 at 12:06 AM. Reason: They |
04-18-2019, 12:17 AM | #5 |
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim |
04-18-2019, 03:05 AM | #6 | |
As far as the "Mikuni" goes. The most common style used here is a VM26 "30mm" clone carb. Link: https://www.amazon.com/Hwbnde-Carbur...SIN=B07CN36W65 It's not really any different than the stock carburetor other than it uses Mikuni main and pilot jets and the carb bore is centered on the flange vs. the Keihin bore offset the stock carb uses, and thus lines up with the intake port perfectly. Now, if you want to spend the money on a Genuine Mikuni VM30 (Smooth bore, round slide) you can use a CRF230F intake to mate it to the head. The CRF intake will need to be ported to match the cylinder head and carburetor outlet however.
04-18-2019, 06:24 AM | #7 |
Thank you all for the info! Its tough asking questions without the bike here yet...so on my old Kawi's and my old Honda the bottom of the brakelight lends is clear (which lights up the license plate)...is that how the Hawk 250 is also? In that case I wouldnt want a red LED, but a white one. If its an 1157 socket, I think I have an extra one in my shop from one of my other builds! Thats great
I am going to buy that knock off carb, and the jetkit that fits it. Im excited to get the bike, its been a while since I had a proper street/trail bike! Thanks again for the info, you guys rock! |
04-18-2019, 06:28 AM | #8 | |
After putting in a 1157 rear LED bulb on my 74-76 Kawi bikes I would get a "pulsing" on the brake light warning light on the dash/tach. It did not mess with the performance per sey, but it did prematurely burn out the little 12v bulb in the tach for the brake light warning. Was a problem until it burnt out, now I dont pay attention to it much haha! |
04-18-2019, 07:49 PM | #10 | |
This might be a better bet for learning and initial set up. |
04-18-2019, 09:05 PM | #11 | |
22.5 Pilot Jet (likely not needed, but providing a link) https://www.amazon.com/Carburetor-In...omotive&sr=1-1 25 pilot jet. (best overall size for a stock or slightly modded bike) https://www.amazon.com/Genuine-Mikun...RB7ACYCJQ2ET6Z 27.5 Pilot jet (works with full mods at lower elevations and colder weather, but may be a bit rich in the hotter months) https://www.amazon.com/Genuine-Mikun...omotive&sr=1-1 30 pilot jet (full mods at sea level and/or cold weather). https://www.amazon.com/Carburetor-In...omotive&sr=1-6
04-18-2019, 09:11 PM | #12 | |
To put it into relative terms. The red bulb becomes 16 times brighter when the full array is lit vs 4 times with the white bulb. They designed it this way intentionally for use as a running/brake dual purpose light. The white light will also pink wash through the red lens.
04-19-2019, 05:18 AM | #13 |
Alright! Thats great to know. So my next question is what is the bulb for the license plate? For me, it only makes sense to have a led on the headlight, taillight and license plate light. Oh good morning from SW PA!
04-19-2019, 05:35 AM | #14 |
If I cant buy the proper led replacement, Im going to buy 2 of those studded led bolts that hold the plate in place, and disable the factory one...
04-19-2019, 06:05 AM | #15 |
I never converted mine over to LED, but I do know that another member here used T10/194 bulbs to convert his bike to full LED and he mentioned the license plate light. It would make sense since that is a common light for that type of application.
