10-16-2019, 01:12 PM | #1 |
Engine ID 1p53fmi
Hello fellow riders!
Picked up an unbranded lifan hoping to swap it into a Honda SL90. Just arrived this morning poorly packed. Stamped on the case it says 1P53FMI and below it says 19040235. The sticker on top shows the shifter pattern as R>N>1>2>3. I purchased it thinking it is a manual 4 up. These are the specs from the listinging: Descriptions: Max Power: 6.5 kW/7500r/min±375r/min Rated Power: 5.6 kW/7500r/min±375r/min Max Torque: 8.0 Nm/5000r/min±250r/min Idle Speed: 1500r/min Min Fuel Consumption: ≤370g/kw.h Ignition System: CDI Start Mode: Kick-starter Spark Plug: A7TC Clutch: Wet multi-plate Transmission:4-speed, Manual clutch,4 Up Carburetor Type: PZ16J Primary Reduction Ratio:3.722 Gear Ratio:2.833/1.706/1.238/0.958 |
10-16-2019, 01:27 PM | #2 |
Should be able to roll the engine over and verify if the sticker is correct, if it is then it was built to be an atv engine.
10-16-2019, 01:31 PM | #3 |
The engine number won't give you any information on whether its a 4 speed or 3 speed with reverse. Looks like they sent you an ATV engine instead of a motorcycle engine. Might be the wrong shift pattern tag if your lucky. Try removing the plug and manually turn the engine to see if it reverses.
10-16-2019, 01:32 PM | #4 |
We must of been typing at the same time. lol I like your shorter version. lol
10-16-2019, 02:50 PM | #5 |
Took the spark plug out and put the shift lever all the way down, cranking the stator cover counter clock wise the sprocket spins ccw too. So I think I am in the clear, though the engine is not nuetral>1>2>3>4 as I wanted.
While I was shifting through the gears, the selector is now stuck in 4th. I cant seem to free it out of gear. Any ideas? Thanks for the quick replys so far! |
10-16-2019, 03:20 PM | #6 |
Try rotating the crank as you try to shift, might not be easy without it mounted but fresh gears don't always shift easy.
10-16-2019, 03:58 PM | #8 |
Please start a thread and keep us updated on the swap. We like lots of pictures.
