12-11-2023, 09:03 PM | #1 |
Front Sprocket Question
Looking to go from a 13 tooth to 17 tooth on a 520 chain.
Are there any reliable or preferred vendors to buy from? New to the forum and new owner so just trying to figure out best options. |
12-12-2023, 08:07 AM | #2 |
That's a pretty big jump. If you haven't already, check to see if there is room in the front sprocket area to fit a 17 tooth. Both at the front but also at the rear, near the swingarm.
More typically you can go up a tooth or two. You might have to do a combination of larger front and smaller rear to get the ratio you want.
12-12-2023, 08:11 AM | #3 |
More than likely a 14 tooth will be the largest that will fit.
12-12-2023, 12:25 PM | #4 |
Thanks for replying back, most appreciated. Do you have a suggested vendor or website that is reliable and go to for these types of parts?
12-12-2023, 01:06 PM | #5 | |
I've started adding parts on my website to have all the information in one place. I still have a lot to add to it. https://jerryhawk250.com/index.php/kpx-parts/
