09-17-2019, 12:17 PM | #1 |
Hawk Rear Sprocket Change: Stripped Nut
It seems the fourth and final nut I was removing from the 4 that mound the rear sprocket is stripped. It spins and spins and never loosens up. Can’t fit a tool underneath it to pry and I think I may have to go the cut-off route.
Two questions: 1. Any tricks to try before getting the grinder out? 2. Where to order a replacement stud/nut? |
09-17-2019, 12:19 PM | #2 |
I replaced mine with actual steel nuts at the hardware store.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
09-17-2019, 12:41 PM | #3 |
Is the stud turning with the nut? if so, With the retainer clip removed you should be able to remove the sprocket with the stud still attached to the sprocket. The Hawk has a cush drive hub. The stud just inserts into the hub. The retainer clip is what holds the sprocket in place.
The stud is Honda Part # 90128-ke2-940 Can be found on Amazon, Ebay, Partzilla
09-17-2019, 12:57 PM | #4 |
Press the sprocket in and then turn the nut. The stud is oval shape and need to press against something to prevent it from turning. Also remove the retaining c-clip carefully with a proper retaining spring tool.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
