Old 05-18-2015, 08:00 PM   #1
Bmwgreenrt   Bmwgreenrt is offline
Accessory Plug Type
I want to hook up a few accessories to the bike to use the A1 and A2 switches. I found the two white plastic male plugs on the left side under the seat. There are no part numbers and it did not come with the female side to hook wires to. Anyone know what the right female connector is and/or where to get them?
Thanks
Old 05-18-2015, 08:30 PM   #2
I doubt we are going to find a match for them, unless they are sold by CSC. However, you might want to check the Radio Shack website.
Personally, I think I will probably remove the white plugs, and replace them with spade connectors.
http://www.oreillyauto.com/site/c/de...ade+connectors
Old 05-18-2015, 10:31 PM   #3
oldqwerty   oldqwerty is offline
Those spade connectors will short to anything metal they touch. Use the 2 wire plugs that come with battery tenders and splice the wires with solder and shrink tubing instead of crimps.
"Thou shall not Zong" is not a commandment.
Old 05-18-2015, 10:45 PM   #4
AZRider   AZRider is offline
I believe that this is the connector that oldqwerty is referring to:
http://www.amazon.com/Allstar-Perfor.../dp/B003C01FD6
George
2016 CanAm Spyder F3-L
Old 05-18-2015, 11:15 PM   #5
Adjuster's Avatar
You can use fully insulated spade connectors or even better marine grade connectors. Marine grade are fully insulated as well as the metal is galvanized against corrosion. All available on Ebay or Amazon and my local ACE Hardware carries them as well.
Old 05-18-2015, 11:24 PM   #6
Adjuster's Avatar
These are really nice as they also have built in heat shrink. Just make sure you get the right size for your wire gauge. I didn't shop around much, may be able to find them at a better price.
http://www.ebay.com/itm/50pcs-3M-Hea...09545269&rt=nc
Old 05-19-2015, 01:01 AM   #7
Yes, they will short if you don't insulate them. I always shrink wrap the connections, or cover them with electrical tape, and I haven't had any problems. In fact, I did a complete dual sport conversion for my Honda, CRF250X dirt bike with these connectors, and after 10,000 miles of hard riding on Rocky Mountain single track, et cetera, the connectors are still doing great, and I haven't had any electrical shorts.
However, I do very much like the 2-wire SAE connectors you recommend. Since space is not an issue in this application, and since one is not making a large number of expensive connections, I think your suggestion is excellent.
Old 05-19-2015, 01:03 AM   #8
Those are also excellent connectors.
Old 05-19-2015, 01:04 AM   #9
I also like the SAE connectors (sometimes called "flat two"), but if space doesn't permit them, then two layers of heat shrink over a spade connector does the job.
Old 05-19-2015, 01:40 AM   #10
Absolutely. Since space, and the number of connections are not an issue, the SAE Flat 2 connectors are an excellent choice for this application.
When wiring external, 12V power outlets on my Zongshen ZS200GY-2 and Honda XR650L, I used the SAE Flat 2 connectors.
http://www.ebay.com/itm/SAE-flanged-...ce96e#shpCntId
I bought the mating, SAE Flat 2 connectors at AutoZone.
http://www.autozone.com/trailer-hitc...et/141583_0_0/
Old 05-19-2015, 01:59 AM   #11
pete   pete is offline
pete's Avatar
don't know about there..here...
go to a auto electrical shop...
remember zongshen or CSC didn't make the connectors
they bought them..so can you...
try Aliexspress.... yer might be shocked what yer find...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-19-2015, 02:08 AM   #12
That is a good point, Pete. These connectors might be unique to China, but I doubt it. However, it certainly doesn't hurt to check.
Nevertheless, if a pair of SAE Flat 2 connectors only costs $2.99, it might be less time consuming, and expensive, to merely make a trip to AutoZone. Since I have a good supply of spade connectors, I might as well use them, save $6, and insulate my connectors well with shrink wrap.
Old 05-19-2015, 02:09 AM   #13
...try Aliexspress.... yer might be shocked what yer find...
That is another good option, as long as someone doesn't mind waiting for the shipment to arrive from China.
Old 05-19-2015, 08:01 AM   #14
Huck369   Huck369 is offline
Huck369's Avatar
The "Accessory" connectors on the RX-3 are very common on Japanese cars....should be available somewhere.
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-19-2015, 08:17 AM   #15
Thanks for posting that good information. Perhaps a Toyota or Honda dealer would have the plugs in stock, or could order them.
