06-18-2021, 11:31 AM | #1 |
Wheel Bearings
I picked up new bearings from All Balls Racing and I started with my front wheel. I tapped out the old bearings (with a learning curve) but I noticed that the spacer had lots of scaring on one side. Is that normal?
Also, I sourced the wrong seals (dust covers?) on both front and back. Anybody have Part numbers for those? How about a cut sheet for wheel assembly for old guys that cant remember how it goes back together? any help is appreciative. Thanks
~ toys in the cave (in the order of addition) 81 Honda XL185s {work in progress} 2018 QIYI Coolster 3150CXC 150cc Quad 2019 QIYI Coolster 125cc Quad 2021 Roughhouse 50 (neat little scooter for the wife) 2022 QIYI Coolster 3150DX-4 I may not be fast but I am "Half-Fast" |
06-18-2021, 10:15 PM | #2 |
Not sure what bike you are working on. But I crossed the seals (on my apollo 250) over to a Suzuk.
06-19-2021, 02:13 AM | #3 |
Sorry, 2020 Hawk 250
06-19-2021, 03:20 AM | #4 |
You may want to look up Megadan on here. He has links to hawk mods and recommendations. He is our guru of motorcycles. Maybe he will chime in here in a bit.
06-19-2021, 10:12 AM | #5 |
The spacer end is just roughly cut and was never cleaned up/smoothed out. You can do so if you desire with a bit of sanding or a file, just don't go removing a ton of metal. Even roughly cut like that it won't affect anything negatively. That spacer is simply there to brace between the inner races when you tighten the axle nut.
As far as seals go, the seal dimensions are listed in the resource guide.
06-20-2021, 01:49 PM | #6 |
thanks Dan, sorry I missed that. I thought that I thoroughly did the search criteria on this but I missed it.
Again, thanks
06-20-2021, 06:05 PM | #7 |
No worries. There is a lot of stuff to look through lol
dust cover, wheel bearings, wheel spacer. |
