10-29-2021, 10:16 PM | #1 |
TBR7 left turn signal stays on
I am garbage with electrical stuff. My front and rear left turn signals will not turn off. They are faintly illuminated. When I turn them on, they flash brighter, but they never turn completely off. I did cut my beeper off
Does anybody know how to fix this? |
10-30-2021, 12:14 AM | #2 |
And what does this green wire connect to??
10-30-2021, 12:39 PM | #3 |
The blinker relays i believe are under the seat. You may have a faulty relay. They look cube shaped and have wires going into them. That's where I would start. I can't remember if they have two separate relays for each side. If they do, you can take a picture of the wires before removing them and swap them into the other relay and see if the problem goes away.
10-30-2021, 01:23 PM | #4 |
Good idea. I’ll see if that switches it from left to right. I already took the switch on the handlebar apart and that did not turn them off.
10-30-2021, 01:24 PM | #5 |
Does anybody know what that green wire next to my battery is supposed to connect to?
10-30-2021, 06:33 PM | #6 |
Pulling the relay and switching the wires does not make it go off.
