Old 04-27-2016, 07:33 AM   #1
keithmaine   keithmaine is offline
keithmaine's Avatar
Tire Life Report
I was hoping to begin a thread that will give us a good idea of how the different tires perform and wear on the RX3
Many times I look at other forums and there are tire battles just like oil threads. So if you would just provide straight feed back on how the tires perform and wear for you. Please let us know terrain involved, road vs dirt etc. as well.
I am running Shinko 244s, but I know others are running Kenda and Shinko 804/805.
So as we gather mileage lets check in and update how our tires are doing.
Thanks
Keith
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
Old 04-27-2016, 09:24 AM   #2
Thanks for starting the great thread, Keith.
I got 13,000 miles of good wear from the Shinko, 244 rear tire in size 5.10-17. This tire performs very well on pavement. The tire also performs well while riding off road on gravel roads, dirt roads, and fire roads, as long as the dirt is not muddy.
Here is a photograph of the Shinko, 244 rear tire after 13,000 miles of wear. I replaced the tire with another Shinko, 244 rear tire, size 4.60-17.
Old 04-27-2016, 10:18 AM   #3
Mudflap   Mudflap is offline
That's amazing Spud! I've never gotten over 4000 miles out of a rear 244, and I'm a pretty conservative rider. Could the rubber compound be different on the 4.10/18 size I use? The one on my Lifan 200 right now is more worn than the one in your pic and only has 3100 miles.
Old 04-27-2016, 10:25 AM   #4
I think the excellent cushion hub on the rear wheel of the RX3 probably contributes a lot to extended tire life. I don't know if the rubber compound is different for the 4.10-18 tire, but I'm betting the cushion hub is the main factor which prolongs rear tire life for the RX3 motorcycle.
Old 04-27-2016, 12:14 PM   #5
dpl096   dpl096 is offline
dpl096's Avatar
That Shinko 244 look like the 510-17 K270 at CSC ... only a lot cheaper! Did you ride the factory tired at all ?
― Thomas Jefferson
Old 04-27-2016, 02:12 PM   #6
You are correct; the Shinko 244 is pretty much a kenda K270 clone, but it is less expensive. Some people think the Shinko 244 tires perform better on pavement than the Kenda K270 tires, especially the front tire. However, some people with larger, faster bikes, have shed knobs from the Shinko, 244 rear tire. I don't think the RX3 will shed knobs because of its lower weight, smaller engine, and excellent cush hub. I have installed the Shinko 244 tires, both front and rear, on several motorcycles, and I have never had any problems with them.
I rode the factory rear tire for several hundred miles until I got a flat. Since it was the sloppy springtime, I seized the opportunity to switch to the Shinko 244 tire at that time. Thereafter, I soon switched to a Kenda, K270 front tire for better traction off road.
The Kenda, K270 front tire lasted a long time, but it wore unevenly. If I had flipped the front tire, it would have lasted much longer. I replaced the Kenda, K270 front tire with a Shinko 244, size 3.00-18 tire.
Old 04-27-2016, 02:30 PM   #7
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
How does a cushion hub make a difference in tire mileage?
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 04-27-2016, 02:42 PM   #8
keithmaine's Avatar
I am no expert but the cush drive absorbs sudden shock to the drive line including the rear tire which would reduce the rear tire skid on down shifting and loss of traction during sudden acceleration. I think perhaps riding style and terrain play greater rolls but every little bit helps.
Old 04-27-2016, 02:50 PM   #9
As Keith replied, riding style and terrain play greater roles, but every little bit helps.
Old 04-27-2016, 08:19 PM   #10
dpl096's Avatar
Quote: The Kenda, K270 front tire lasted a long time, but it wore unevenly. If I had flipped the front tire, it would have lasted much longer. I replaced the Kenda, K270 front tire with a Shinko 244, size 3.00-18 tire............
My riding will be 70/30 paved to gravel-dirt back roads..... Would you suggest the Shinkos are superior in better handling for such conditions...
― Thomas Jefferson
Old 04-27-2016, 09:44 PM   #11
I think either the Shinko 244, or the Kenda K270 tires will serve you well for that type of riding. The Shinko tires cost less, so you might as well try them first. I like the Shinko 244 tires a lot; they have served me well.
Old 04-27-2016, 10:19 PM   #12
Lee R   Lee R is offline
Lee R's Avatar
I'm at 2000 and counting on Shinko 804/805s. I like them but will probably try the 244 for the reduced cost in the future.
Old 04-28-2016, 06:41 AM   #13
keithmaine's Avatar
Lee
please keep us posted on these tires
thanks
Keith
Old 04-28-2016, 08:59 PM   #14
GSC   GSC is offline
Ryan disclosed that my rear tire replacement choice K784 being oversized may rub a bit when shock is bottomed out, Due to my lowering link.
The experience and complete disclosure before purchase of CSC is so cool!
Anyway any experience with oversize tires and a lowering link RUB at shock bottoming out. Can't decide if I should take the risk. Front shock yes but no memory of rear?
Old 04-28-2016, 10:25 PM   #15
rtking   rtking is offline
CSC is a class act. Ryan, Steve, Joe, Gerry, Sara... every one of them. (Sorry CSC Crew - can't recall everyone's name.) Great that they provide disclosure up front... part of their amazingly honest approach.
I would check with Ryan on his thoughts about the rubbing. I think your airbox is above the rear tire, so that's what would take the brunt of any rubbing on compression. Maybe Ryan may have an alternative recommendation for a tire that might work?
