04-07-2019, 03:34 PM | #1 |
Boom vader needs a battery!
got a 2017 boom vader, need battery suggestions
i was looking at https://smile.amazon.com/YTX5L-BS-Hi...s%2C150&sr=8-7 but not sure if 90cca is enough? |
04-12-2019, 10:12 PM | #2 |
no ones got a different battery? or some numbers i can match to?
04-13-2019, 12:36 AM | #3 | |
I bought the one u listed for the 190 sorry I can't tell you how it worked as I haven't got the 190 in yet. It does have 110cca which is pretty good.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
04-13-2019, 04:01 AM | #5 | |
04-13-2019, 10:03 AM | #6 |
I replaced my 2004 Sportster battery at AutoZone, took it out and showed it to them and they matched it, same dimension battery but better capacity ,it wasn't too expensive ( way less than one from Dealer ) .
They did have to order it but it was there in 2-3 days ,so I'd assume they could do the same for a Vader.,and finally Kronik Racing in Cali can hook you up on anything Vader.
04-13-2019, 06:28 PM | #7 |
thanks guys
