02-01-2016, 05:05 PM | #1 |
Hawk Battery
Anyone have a link to a good replacement battery for the Hawk, perferably a sealed unit? I don't have much faith that the battery which came with the bike is going to last very long.
also, does everyone find that the reg/rec is strong enough to keep the battery good when used regularly? I do intend to keep it on a trickle charger when sitting, but just wondering if a better reg/rec would be worth it. |
02-01-2016, 05:33 PM | #2 |
Sport Rider no Walmart for the battery. reg/rec is fine don't change. Also we use Walmart brand of oil in our racing bikes, this time of the year ice racing .
02-01-2016, 05:45 PM | #3 |
I have never had my hawk on the charger and it always starts. I recently came back from a three week trip and it started right up. As for a replacement this is what I will be using when the battery dies.
http://www.amazon.com/Battery-Tender.../dp/B00F9LPIAC The advantage of this battery if you were to unhook it for the winter it would hold its charge. The standard battery is a 12v9ah battery.
Brandon 2014 Hawk 250 Firehawk minibike Previous bikes~ 1995 Yamaha YZ125 1998 Yamaha YZ250 1981 Yamaha YZ465 1987 Honda TRX 250R X2 one stock one modified 2002 Buell Blast 2001 Buell X1 Lightning 2000 Kawasaki ZR7 |
02-01-2016, 06:09 PM | #4 | |
fitze, I've heard nothing but wonderful things from others about the store brand Walmart oil. "Supertech" I think? We have an engine builder up here in our parts that swears by the stuff.
02-02-2016, 10:28 AM | #5 |
Sport Rider, I've had good luck with the reg/rec on my Honda clones, with only one failure that I can remember. It was such that there was a draw on the battery when the engine was off. Upon changing the reg/rec, the problem was solved.
02-02-2016, 11:11 AM | #6 |
thank you for all the info guys. I'm not concerned about it, just asked more for reference. I've owned some other bikes in the past that have had R/Rs which were poor design (in terms of heat dispersion) or poor location and needed to be moved to a location with more air. as we know, heat kills them faster!
02-02-2016, 01:43 PM | #7 |
2LZ, thanks for the info on the batteries, need to remember that on my next purchase. I only own 2 wally batteries that are about 4 years old for my 750 and 400 Hondamatics.
Yes, SuperTech is the name. Plus it's the oil we use in our big drag bikes for years now. |
02-02-2016, 05:46 PM | #8 |
The small batteries for motorcycles, lawn and garden etc at my local WalMart are all sealed gel no maintenance. I haven't seen an acid filled motorcycle battery at WalMart in over a year.
Besides I thought everyone was buying these? http://www.amazon.com/Shorai-LFX14A1.../dp/B0056H6CP4 Although I do like that Battery Tender battery, I am a fan of all Battery Tender products coming from a boating point of view. / |
03-22-2016, 05:58 PM | #9 |
My Hawk battery just died after about 2 months.....dead cell. Didn't expect it to last long and it didn't!
03-22-2016, 06:29 PM | #10 |
I left my battery on my bike all winter and surprisingly it fired right up. Couldn't believe it. I figured it would be dead.
03-22-2016, 07:16 PM | #11 |
Yup, same here, parked both Hawks mid November, left the batteries in, had some Five Below Zero weather over the winter and they were in Cold Storage. Took them out a few weeks ago and both bikes crank right up without issue.
03-22-2016, 07:55 PM | #12 | |
Check out http://www.pqiamerica.com/ for more info on dozens of brands and oil samples. This link has the SuperTech Diesel 15w40 report http://www.pqiamerica.com/May%202013/supertech.htm Another plus, buying Oil/Auto products from Walmart... they barely make any $ on those items for mark up, it's one of those inexpensive items to "get you in the store to shop for other huge mark up items"
03-22-2016, 08:12 PM | #13 |
I have had 3 Vehicles fed with supertech oil(no prob) but then again I change oil every 5000 miles. Good and cheap stuff AZ is right, as long as it meets those certifications , the trick is keeping it fresh. Hell, the synthetic is cheap enough and I use it exclusively on one of mine. I did make sure I found the correct oil for this bike with the JASO motorcycle distinction. How cool is it that it's just Rotella oil
Does Super tech diesel have the JASO cert like rotella?
